Installing Turbo Oil Feed + Return Lines?
Hey guys.. I'm at a lost to this, where do the feed lines need to be installed on the block to supply oil for the turbo?
I'm assuming I'll need to tap my valvecover or maybe T off a line?
Also, for the oil drain, where is it recommended to tap the oil pan?
for the feed line you need a 90 degree 3/8" npt to -4 an fitting , right above the oil filter theres a 3/8" plug port on the oil pump...
you'll need 4 feet of -4 line and a 12mm to -4 banjo fitting for the turbo ..
on the oil drain I suggest using -10 line or 5/8" , theres a thread on here by kungfu on where to tap the oil pan
Biggy VIII
Aug 9, 2016 03:06 PM
Craig King
Jun 15, 2013 09:30 PM
diablo1
Jul 14, 2011 08:46 PM
