P0107
Old Jan 11, 2011 | 03:18 PM
Mitsu.kid.02's Avatar
P0107
I got a code P0107 i thought it was for the MAP sensor, but, it was actually for the barometric sensor (sensor inside the MAF sensor). Here is info from ALLDATA:
CIRCUIT OPERATION
  • A 5-volt voltage is supplied to the barometric pressure sensor power terminal (terminal 1) from the ECM (terminal 81) or PCM (terminal 46) <A T>. The ground terminal (terminal 5) is grounded with ECM (terminal 40) or PCM (terminal 16) <A T>.
  • A voltage that is proportional to the atmospheric pressure is sent to the ECM (terminal 85) or PCM (terminal 55) <A T>from the barometric pressure sensor output terminal (terminal 2).
TECHNICAL DESCRIPTION
  • The barometric pressure sensor outputs a voltage which corresponds to the barometric pressure.
  • The ECM or PCM checks whether this voltage is within a specified range.
DTC SET CONDITIONS
Check Conditions
  • 2 seconds or more have passed since the starting sequence was completed.
  • Battery positive voltage is higher than 8 volts .
Judgement Criteria
  • Barometric pressure sensor output signal has continued to be approximately 50 kPa (7.2 psi) or lower (approximately 15,000 ft above sea level) for 10 seconds .
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are:
  • Barometric pressure sensor failed.
  • Open or shorted barometric pressure sensor circuit, or loose connector.
  • ECM failed.
  • PCM failed.
Did you notice how it said for the DTC set conditions if its reciving 7.2 PSI for more than ten seconds it will set the code, is this because im turbo now? Have u guys gotten this code before? and i dont think the MAF or barometri sensor should even see any PSI becuse its BEFORE the turbo right?
Old Jan 11, 2011 | 03:29 PM
All data is saying its the MAF sensor, well the barometric sensor in the MAF sensor, but if u put that code on google ever one else is saying its the MAP sensor on the mani... how should i go about diag'in this?
Old Jan 11, 2011 | 04:58 PM
Demon_ni2's Avatar
I trust alldata with my life...
Old Jan 11, 2011 | 08:37 PM
was that sarcastic?? lol
Old Jan 11, 2011 | 09:53 PM
Demon_ni2's Avatar
no.. i mean alldata is pretty f*n good.. as long as ur lookin up the correct car/model etc etc. most dealers use it.. lol
Old Jan 11, 2011 | 09:56 PM
Oh ok lol, hmmm
christianreed91
Sep 11, 2016 09:12 PM
han74j
Sep 12, 2014 05:54 PM
evo9nuuub
Jun 28, 2010 02:00 PM
Nesiop
Aug 12, 2009 09:38 AM
BadazzCR
Aug 23, 2008 07:40 AM
