How does my turbo look?
Old Sep 9, 2011 | 11:40 PM
  #31
jakermeister's Avatar
Yeah LOL I've nearly high centered my car before. The douch that was plowing the snow didn't plow our parking area at work and I was forced into about 10" of snow
Old Sep 13, 2011 | 05:56 PM
  #32
Couple of questions: How much vacuum hose do I need & what diameter? Also, do I NEED to swap my fuel pump to a walbro for 5psi?
Old Sep 13, 2011 | 07:19 PM
  #33
03lances's Avatar
Stock fuel pump is more than enough for 5psi. As for vacuum line it depends on a couple things. Stock evo 8 bov uses 1/8" line and the evo 9 uses 1/4". If your using some aftermarket bov then you will have to bring it down to the store and find out. If your going to have a mbc I know my forge unos uses 1/4" line. I would get 6-10' or more depending on where your going to be routing everything.
Old Sep 13, 2011 | 08:25 PM
  #34
Cool. I got a evo 9 bov I'm so close yet so far LOL All the little things are slowing me down. Also 03lances I read every single page of your build over the weekend. Was pretty informative.
Old Sep 20, 2011 | 05:08 PM
  #35
lncrphish's Avatar
OK, so Good job on boosting your lancer. Some Questions: Why would you go for target of 5 psi? You will not really feel that much increase in power. You are going to do a lot of work and just be disappointed when you finish and take it on your first run. A manual boost controller will not be that accurate to give you 5 psi all the time. In-fact it will probably raise your boost more than anything. I run stock internals with 7-10 psi and I originally had a mbc to try and keep my boost to a max of 7psi but it would spike above 10 sometimes. Now i just run the forge waste gate straight up with 7 to 10 psi spring and it does not spike but gets my spool going faster and boost does not go above 10 psi. it feels great when i go WOT and holds more consistent boost. You should really Get the fuel pump and run 7-10 psi. 440 injectors if you feel confident you can tune it or take it somewhere. I tried the 440's with ecuflash but found that the fmu did the same thing and I saved more on gas $$$$. Just some things to think about. I have had my lancer boosting for 4 years or more now and have only had to replace the manifold because it had developed some cracks,(drilled out megan mani).
Old Sep 20, 2011 | 05:21 PM
  #36
Haven't boosted my lancer yet but I'll defiantly take your advice into account. My current plan is to run 5psi for now and up it later. The wife got a new jeep. So internals won't be for about 5 years LOL. I'm still putting things together. I hope I can get a tactrix cable next to get a hold of the logging and stuff. I'm getting closer each pay period to boosting LOL. All the little things are slowing it down tho. I still guestimate I'll have everything on by October and tuning thru out the winter.
Old Sep 20, 2011 | 05:44 PM
  #37
lncrphish's Avatar
I know how it is man. It took me a little more than a year to collect parts and research the build. and than the install budget ran way deeper than i expected, but at the end, It was so good to have it done. It's almost like you are having a baby and you have to wait 9 months but you want it out NOW. You have all kinds of questions and fears but it will all be worth it at the end. I am always available if you have any questions. More than happy to help out another lancer guy.
Old Sep 20, 2011 | 06:17 PM
  #38
Thanks man! I'm still gathering parts but have most major parts. I'll be put up a build thread when I start mounting parts . With the wealth of information and fellow lancer members I don't anticipate too much trouble. I defiantly want to put the parts on before it snows here. Last year we had a lot of snow and this years weather has been moist as well.
Old Aug 28, 2012 | 12:01 PM
  #39
2OO3SILVEREVO's Avatar
good plans lol
Old Aug 28, 2012 | 01:09 PM
  #40
ryancb's Avatar
way to bump a year old thread...newb
Old Aug 28, 2012 | 01:50 PM
  #41
Grind3r's Avatar
And you know it wont be the last either
Old Aug 28, 2012 | 05:51 PM
  #42
LMAO its been a while but we are working on a new kit. I don't have a mom and dad to buy me a evo.
Old Aug 28, 2012 | 05:57 PM
  #43
Grind3r's Avatar
Totally know what you mean...No EVO yet...not saying at some point I might upgrade or add one as a second vehicle. But I do love my Boosted Lancer ....
So when you say your working on a new kit....Are you per say hinting your close to adding Boost to yours... That would be SWEET. Always room for another in the family
Old Aug 28, 2012 | 07:42 PM
  #44
Been working on boosting for a while and then decided to go a new route. You can look thru my thread (its not as long as the others LOL) and see my progress. The 04-06 lancers aren't as lucky as the 02-03 lancers beautifulpunk is working on the kit. His work is awesome. Its basically a custom manifold without the custom price. He has a lancer and if you need any parts hit him with a PM.
Old Sep 6, 2012 | 10:53 AM
  #45
Green_Bandit's Avatar
Man, bye. I'm not even going to attempt to explain how wrong you are on so many levels.
