turbo for U.S. Lancer
Ok, I'm gonna have to step up and be the dick. If you're gonna have enough time to do FI on your lancer, you're gonna have to take the time to do a little research. Seriously. Use the search button. There's a whole forum dedicated to just engine and drivetrain.
Good luck.
Good luck.
RRM's turbo is too expensive for not that much gain compared to other turbo's i've seen....watch this...http://www.importperformanceparts.ne...itsubishi.html
ok that kit will not produce 280, or 250, hell it'll be a fun time trying to get over 210. I think they are shootin waaaay too high with those numbers.
You should really use the search button like engineerboy said, seriously, there's so much info out there like you woulnd't believe. Good luck with everything though!
Ok, I retract some of my previous statement. Flat Lander Racing get's big ups for what they've done with mitsu in the past. I haven't seen much but it's been impressive. If I go FI it will be their t25BB extreme kit. More power AND I have enough saved (compared to the RRM turbo) to get it installed if I'm feelin' lazy.
But, there's a LONG thread on this turbo in the FI forum
Bobaab- Sure, no one's gonna make those numbers. BUt then who's making the RRM 230WHP
I think Boe MIGHT be, and a couple guys were saying after some tweak they'd get about 210. So if 230 RRM WHP=210 real life WHP then hopefully 250 FLR WHP= at least 220real life WHP.
petey- the basic kit doesn't come with a BOV. The extreme kit comes with MORE than the RRM kit. AND The 1.8L lancer is the car that graces the rest of the world. Here it was called the Mirage (well, the engines are the same IIRR). They get MAD boost because the heads and walls are so much stronger than out almost overbored 1.998L engines
that's my point. Boe got tons of extras and all the guys at RRM working on his car. The guys that are making 210 (I think liquidlancer is one of 'em) have still put LOTS of extras into their cars. Most guys are getting about 170WHP out of the turbo. Which is about a 60-68 WHP increase over stock (depends on who you talk to)
I give the ball bearing turbo the edge over the standard sleeve bearing turbo anyday. BBs are extremely low friction and spool much faster.
Maybe I'm missing what you're trying to say. . .
