Simon's GTS Turbo Build
Old Apr 9, 2013 | 08:47 PM
Simon Pugmire's Avatar
ok so now this is the second time writing this i took too long writing it so it logged me out when i went to submit than it never showed up. SO anyways im about to turbo my 4b12 and im just waiting on my last parts to show up in the mail and the weather to clear up. Here is a list of parts i have incase someone wants to do the build themselves.
RA Turbo
Kinugawa EVOX WG (.3 bar psi spring )
RA Downpipe
RA Manifold
RA Piping
RA FMIC
RA Injectors
RA Snorkle for air intake with 3" K&N Air Filter
AEM UEGO Wideband Air/Fuel Ratio Gauge
Prosports Boost Gauge
Glow Shift Oil pressure gauge
34MM Recirculating Dump Valve
4AN hose for oil feed
6AN hoses for coolant lines
8AN hose for oil return
all fittings for the hoses
Turbo Smart manual boost controller
NGK Iridium IX 2668 spark plugs
OMNI 3 Bar MAP sensor
As for the tune im flashing over a EVOX ROM and have someone etune for me.
Im looking to be around 220-240 WHP with 7-8 PSI. I will be installing this as soon as the weather here in the midwest clears up and stops having a bipolar winter.
Old Apr 10, 2013 | 11:36 AM
LiX's Avatar
LiX
I suppose you are prepared for the CEL which will disable your MIVEC?
Old Apr 10, 2013 | 11:41 AM
yup yup i also have been doing some research and i am sure i can enable the mivec im not 100% but i seen on a forums someone telling how they got it to work again or something like that has to deal with something by the cams and you have to get it from a stock EVOX but im not worried about losing mivec
Old Apr 10, 2013 | 11:59 AM
LiX's Avatar
LiX
Evo X ECU is what you need, error is for the exhaust cam position sensor, but nothing cam related have to be changed.
Old Apr 10, 2013 | 10:28 PM
yeah didnt read that much on it it was more of a skim thing. im not worried about having the mivec right now, i just want to be turbod.
razorlab
5165
Aug 11, 2024 07:56 PM
jakermeister
503
May 16, 2016 02:03 AM
Ibetchuwontdoit
Jun 11, 2015 01:44 AM
Simon Pugmire
Apr 13, 2013 07:30 AM
villero1834
18
Apr 8, 2011 03:53 PM
