Oil for turbo lancer?
Old Mar 2, 2004 | 04:29 PM
fkrzo's Avatar
Yeah sure, and so is the W in 20w50.
*name calling deleted* - UK
Old Mar 3, 2004 | 01:56 PM
tenkawa_akito's Avatar
Re: oil
Originally posted by gt4007
Synthetic holds viscosity and general qualities to much higher temps such as those created by our turbo.
Synthetic oils resist thermal breakdown better than traditional dino oils. Viscosity is viscosity.
Originally posted by Boni
Go ahead and put synthetic if you are a baller and can afford an oil-change every 700-1000 miles because if you run youre car hard thats when you will need to change it (boosted motors that is). Just better to be on the safe side the HP increase isnt really that much from what i've heard. Unless your boosting 20+ psi and youre only going to be running 5-7.
I use 20w50 pennzoil because a wise pimp once told me so.
later fools.
Why would you have to change oil every 700 miles if you run synthetic? The very earliest you would have to change your oil is every 2000 miles. Water cooling jackets helped knock the minimum ceiling up. if you run an old, non water cooled turbo, then yeah, you would have to change your oil before 1000 miles was up.
Old Mar 3, 2004 | 02:26 PM
Boni's Avatar
Re: Re: oil
You don't know what your'e talking about,
Old Mar 3, 2004 | 05:04 PM
Kontradictions's Avatar
valvoline VR-1 20w50
nothing more, nothing less...and actually i need to get an oil change ASAP!
Old Mar 3, 2004 | 10:56 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Re: Re: oil
My understanding is that thermal breakdown affects the viscosity of an oil. As it breaks down, it creates more friction, which is why engines that go without regular oil changes experience excessive wear and tear.
edit: oh yeah, if you decide to stay with dino oil (like me, but my Lancer will probably never have a turbo) I recommend that you stay away from parafin based oils. They tend to gum up easier than non-parafin oils. I recommend Valvoline or Castrol.
Old Mar 3, 2004 | 11:07 PM
Moderator
Bomb Squad Unit #02
***Public service message***
Please be respectful on these forums, everybody. Most of you I recognize as respected members who usually have useful and helpful information to share, but this name calling and flaming is unacceptable. If I have to clean this thread again, it goes in the trash.
Old Mar 4, 2004 | 07:37 AM
Thank you Brian
btw, is mobile 1's dino line parafin based? I use mobile 1 synthetic, so it doesn't affect me per se, but it's always nice to know for reference
EDIT:
You're right. But synthetics still resist breakdown better.
Old Mar 4, 2004 | 07:48 AM
gt4007's Avatar
lead and oil
One question I do have is running leaded fuel a problem with sythetic oil. I ran Snytec in my aircooled airplane motor, but the manufacturer said the leaded gas would cause the synthetic to sludge. By the way our oil temps woud hit 300 degrees on climb which would roast most standard oils.
Old Mar 4, 2004 | 07:51 AM
ZooRacer's Avatar
i have been running Synthetic since my second oil change at 6000 miles and now i am at 33000 miles and neva had a problem...
Old Mar 4, 2004 | 07:56 AM
brentg07's Avatar
ive been runnin synthetic for me it stay a lot cleaner a lot longer
Old Mar 4, 2004 | 08:40 AM
TURBOit's Avatar
to my understanding, the lancer oil pump just can't handle a synthetic oil while being boosted
also, there are people posting what oil they use but be sure to check their reg because they don't all have turbos
Old Mar 4, 2004 | 08:54 AM
gt4007's Avatar
oil pump
Any oil pump that can pump regular oil can pump synthetic. The physical properties are the same, just more consistant through the temp ranges.
Old Mar 4, 2004 | 11:27 AM
Moderator
Bomb Squad Unit #02
Thank you Brian
EDIT:
I honestly don't know. I just read the labels of my valvoline and castrol bottles, and they don't say anything about parafin. Maybe this is just outdated wisdom (my father passed that information down to me). And yeah, synthetics resist breakdown better, which is why you can last longer without an oil change. I'm just happy my Lancer runs 3000 miles on dino oil and still doesn't turn it too dark. My dad's old mustang turns it black after about 1000.
Would somebody summon Rock to explain why he says synthetics are not a good idea? Oh yeah, he got sick of explaining it to us
Old Mar 4, 2004 | 07:45 PM
pgmike's Avatar
yeah noticed that too, dont know why they are posting what they use really.
im just going to be on the safe side and not use synthetic, thanks guys.
Old Mar 25, 2004 | 06:26 PM
sadude's Avatar
i haven't checked my manual lately but does it recommend 20W50 cause right now I am using 5W30 and my oil light is coming on when i stop
is this oil too thin???
