eManage vs S-AFC
Old Mar 30, 2004 | 11:31 AM
Drive02Lancer's Avatar
Question eManage vs S-AFC
what are the main differences?
between the GReddy eManage(just the eManage and harness to the laptop, not all the extra stuff u can get) and the Apex'i S-AFC?
which one allows u to tune more?
thanks
rich
Old Apr 1, 2004 | 09:36 AM
pgmike's Avatar
bump
Old Apr 1, 2004 | 09:42 AM
sillypuddy's Avatar
i had the vafc (same except for the vtec control) and on the dyno you will notice that it doesn't react fast enough.. there are little spikes in the a/f
the emange is a bit faster and can react better.. gives you more control like spark etc
-joe
Old Apr 1, 2004 | 09:47 AM
evoego's Avatar
Registered User
the emanage is 100 times better and has almost unlimited tuning abilities. Its as close to a stand alone as they come and even shares some features with them. PM me for more info if needed.
Old Apr 1, 2004 | 09:53 AM
rhyzin's Avatar
the emanage also uses a spreadsheet to input corrections giving you actual points in RPM vs Throttle Position for Airflow correction, meaning more tunable correction points.
the safc just gives you a HI and LO map to make corrections and interpolate the 2 to come up with one complete fuel map.
hands down the emanage is better to tune with, and with all the add-on harnesses you can put, leaves better flexibility in the future. the emanage with all the bells and whistles will do a better than decent job datalogging. though i don't have an emanage, i've been doing my homework and feel it's something i'm going to "graduate" to from my current apexi safc.
Old Apr 1, 2004 | 11:36 AM
JVlancer's Avatar
by the way on the HI LO settings on SAFC if your running turbo you have to set the LO to 98% and the HI to 99% and let the ecu do most of the work... at least thats how i get it to work perfectly with my car.
evoboy8990
Feb 14, 2007 09:41 AM
LostSoul Evo
Jul 26, 2005 05:46 PM
supernavagator
Apr 8, 2005 05:21 AM
LancerEVOmann
Jan 10, 2005 06:26 PM
IS2000
Jun 3, 2003 09:48 PM
