4b11 plus turbo problems
Old Aug 7, 2022 | 09:31 AM
Jake__2022's Avatar
Hi iam just finished adding a turbo on a '17 lancer gta and having some problems.
Rough idling even if i drove it for an hour to relearn the ecu, also it has a cel codes p0068 (maf, map, tps correlation) and p061a (torque monitoring). The ecu is not flashed yet. Anyone with experience could chime in. Thanks
heres the pic of the engine btw
Old Aug 9, 2022 | 05:49 AM
Isaque's Avatar
You need to flash a basemap on your ECU with a turbo map or use a RA/Evo X ECU with a map. How do you expect a NA rom to function with a turbo setup. Hit up HTuning on Facebook and we can set you up.
Old Aug 25, 2022 | 08:54 PM
notevo's Avatar
@Isaque can i use a ralliart ecu with my es? or do i need to like reprogram the vin?
Old Aug 26, 2022 | 08:45 PM
Isaque's Avatar
If it’s a manual yes you can use RA ECU but it’ll need to be vin written and flashed with proper rom for it. If it’s cvt. best to use stock ecu.
Old Jan 15, 2023 | 10:11 PM
bandyman's Avatar
Hey man is there a way that you could relink this? I am also right at the end of boosting my lancer, and all that i need now is a base rom for the ralliart ecu that i have put in. I have already coded my vin into it using MMCodingWriter, but even then it idels really rough and then stalls
Old Jan 16, 2023 | 04:56 AM
Isaque's Avatar
HTuning can tune you if you’d like. Mmcoding can’t flash rims on your car. If you didn’t change rom. I wouldn’t be firing it up.
hit me up on Facebook Mitsubishi lancer turbo club group 🤙🏼
yesevo
Dec 27, 2006 06:23 AM
joshthegreat
Lancer Engine Management / Tuning Forums
Aug 21, 2006 11:55 AM
lilgdogger84
Lancer Engine Tech
14
Oct 27, 2004 08:26 PM
josh930
Lancer Engine Tech
10
Sep 10, 2003 10:27 PM
