R/C or Vent?
Old Apr 18, 2004 | 01:29 AM
twinkiemobile's Avatar
R/C or Vent?
What is the advantages or disadvantages of either..
1.) Having a Recirculating BOV or having one that vents all into the Atmosphere?
2.) Moreover, will the HKS SSQV work with the RRM turbo kit? what would i have to do to make my turbo kit vent all into the atmosphre?
Old Apr 18, 2004 | 05:40 PM
IILANCERII02's Avatar
u heard that particular bov has trouble fitting with the RRM kit and requires minor modification, but the Greddy - Type S works really well.
Old Apr 18, 2004 | 05:57 PM
osunick's Avatar
I don't know about lancer turbo kits, but a VTA BOV on an Evo will cause idle problems because the MAF sensor is misreading the air coming in and it overcompensates by making the car run too rich..
Old Apr 18, 2004 | 06:43 PM
i havent heard anything about that for the regular lancer and i think there are quit a few people on these forums that have their bov venting - so we shall just wait for them to respond.
Old Apr 19, 2004 | 05:42 AM
gokusupersaiyen's Avatar
respond i will
i have my type-s vta, it has a maf just like the evo so it will have the same problems with stalling but its not bad, it only happens if you shift at a high rpm blow off and dont get it a little bump on the gas before it goes back to idle. if you just shift and put it in the next gear its fine. i have had mine die a few times i never even notice it.. sounds good too
Old Apr 19, 2004 | 10:09 AM
tenkawa_akito's Avatar
If you want to run a BOV without having any problems, you'll need to have a MAP instead of MAS (the MAP reads air pressure in the intake manifold, instead of metering air as it comes in the intake). I personally prefer to recirculate because you don't have any quirky idle problems and you get a slightly better gas economy.
Old Apr 19, 2004 | 10:23 AM
HobieKopek's Avatar
On a stock ECU recirculate. Unless you're SO keen on the sound that you don't mind the extra fuel consumption (minor), stuttering and stalling (fairly major). In that case...whatever puts a grin on your ugly mug.
Old Apr 19, 2004 | 03:57 PM
would i have stalling problems if i vent and have an automatic?
