T-28 Turbo
Old Sep 20, 2004 | 08:01 PM
BlueIrishs2k's Avatar
T-28 Turbo
Is ANY Garrett T-28 turbo compatible for putting on an OZ Lancer with all the other work being custom?
Old Sep 20, 2004 | 08:12 PM
bahamut's Avatar
Sure, a T28 will work on a lancer, just need a TC mani. You'll be making HP figures around the Silvia S15, just w/o the BB.
Old Sep 20, 2004 | 08:27 PM
Hotshot940's Avatar
i recommend the T-28 on the lancer, it works very well. if you can get the garrett BIG T-28, its got the oversized compressor wheel. its niiiiice.
Old Sep 20, 2004 | 09:09 PM
4G63 Racer's Avatar
For the best turbo selection go to http://www.Forcedperformance.com
Old Sep 21, 2004 | 06:46 AM
Cool. The reason I ask is that I can pick up a used (about 20,000 miles) T28 for about $200.00. I'm going to have a local shop check it out for me but didn't want to waste my time if it wasn't going to work with it.
Old Sep 21, 2004 | 06:50 AM
livelyjay's Avatar
Since we're on the topic, the RRM kit comes with a T-28, while the other kits available come with T-25s and for some $$ be upgraded to the T-28. Can the T-28 be rebuilt and upgraded during the rebuild?
Old Sep 21, 2004 | 07:27 AM
Boeturbolancer's Avatar
Actually RRM kit comes with the Big T-28... there is a difference between the T-28 and the Big T-28. It is a good comparison though as the T-25 is a good turbo if 200whp is your goal... much more than that and you'll max it out. The T-28 should get you about 225-240whp and the Big T-28 is capable of 300+whp. It's all about your goals and what your motor is built like.
Old Sep 21, 2004 | 08:10 AM
Hotshot940's Avatar
mmmmhhhmmmmm Big T-28, yuumm
Old Oct 7, 2004 | 08:39 AM
blacklancer03's Avatar
hey if you get the t25 kit. and all that..
then wanna throw a t28 on later.. can you just drop it onto that manifold
Old Oct 13, 2004 | 08:04 AM
OZ-Guy's Avatar
good question.. any answers?
Old Oct 13, 2004 | 01:22 PM
ghostrider's Avatar
Not sure if the t25 and t28 share the same flange. If they do, then it's a matter of pulling out one turbo and swapping in the other. If not you'll need to get a new flange or an adaptor plate welded onto the manifold first then you stick the new turbo on.
Old Oct 17, 2004 | 05:12 PM
Sonantoni's Avatar
I believe they have the same flange and also depends on which way the outlet side of the compressor faces if you have to do any modifications to your piping. Most turbo's outlets faces the driver's side, RRM modifies theirs for the intercooled setup to the passenger side for the intercooler.
Old Oct 17, 2004 | 06:26 PM
4G63 Racer's Avatar
yes they do have the same flange, for sure, and if your buying it for a dsm they will face the same way I promise.
Old Oct 23, 2004 | 10:10 PM
phisheys's Avatar
The t28 BB sounds good, but has anyone out there put a t3 on a lancer??? Or is that even possible?
Old Oct 23, 2004 | 10:36 PM
i think omarboy25 is running a t3/4 hybrid... try pming him.
As answered before the t-28, t-25,big t-28 share the same flanges.
