Can I Do This?
Old Oct 14, 2004 | 04:18 AM
LOTL's Avatar
Can I Do This?
i have 3 audioban awis10p 1500 rms each i am going to get 2 audiobahn amps but one amp at a time each amp is 2400 rms each theres gonan be like a 3 week delay untill i have both amps so im only gonna have one for now, anyway my question is can i bridge those 3 subs and use that amp? i dont want my amp to mess up or anything
Old Oct 14, 2004 | 06:41 AM
BillAce's Avatar
What impedance are the subs? The amp won't give 2400 watts if it was struck by lightning. They are pretty though.
Old Oct 14, 2004 | 03:21 PM
OZrallyats's Avatar
The amp should be able to run stable at two ohms.
Your subs need to be 8 ohms. Then you could run all three in a parrallel circuit (bridge) Take the 8 ohm load of the sub/ the number of loads (subs) 8/3= 2.66 ohms. The amp would see a 2.66 load.
Most subs are only 4 ohms though. Then this set up would blow the amp 4/3 = 1.33 ohms, way to low unless you got a class D amp.
If they are dual voice coil subs. Wiring both voice coils in series will make each sub 8 ohms and then you could do this.
Let us know a little more about the subs and the amp.
Old Oct 14, 2004 | 09:36 PM
LOTL's Avatar
thanx for the help OZrally i apperciate it
here are the sub specs
3000 Watts Peak Power Handling
1500 watts R.M.S. Power Handling
Proprietary Tall Excursion Foam Surround: Allows For Maximum Excursion and Maximum Cone Surface Area
Ultra Light 2-Layer Carbon Fiber, Kevlar® Cone with Aluminum Dustcap
200 oz. Triple Stack Magnet
25mm Top Plate for Increased Efficiency
3" Quad 2 Ohm Voice Coil Wound on Black Anodized Aluminum Former
.5, 2, or 8 ohm operation for single sub
.5, 1, 2, 4, or 8 ohm operation for two subs
Multi-Connect Lug Lock Terminals
Chrome Plated 3-Dimensional Cast Aluminium Basket
Dual Layer Spyder
Frequency Response: 28Hz-700Hz
Efficiency: 93dB
Mounting Depth: 8-1/4"
and the amp specs:
4800 Watt 2 Channel High Current Amp
300 watts RMS x 2 @ 4 ohms stereo
600 watts RMS x 2 @ 2 ohms stereo
1200 watts RMS x 2 @ 1 ohm stereo
2400 watts MAX x 2 @ 1 ohm stereo
2400 watts RMS x 1 @ 1 ohms mono
4800 watts MAX x 1 @ 1 ohms mono
High Current Circuitry
PWM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Old Oct 14, 2004 | 10:18 PM
twardnw's Avatar
if you set each sub up so that it was an 8 ohm load on it's own, the connected them in parallel to the amp it would work
Old Oct 15, 2004 | 07:22 AM
BillAce's Avatar
Does that amp have a 400 amp fuse?
Old Oct 15, 2004 | 07:55 AM
SK Lancer's Avatar
Exactly what I was thinking.
How big is this amp?
Old Oct 15, 2004 | 09:06 AM
OZrallyats's Avatar
like tward said, best bet right now is wire each sub's own coils in series to get an 8 ohm load (2+2+2+2) Then take the 3 subs and parrallel them to the amp and you should be running at 2.66 ohm. Although we havent gotten the subs down to one ohm, at 2.66 the bass will be cleaner and the amp wont run near as hot.
I would try this before even ordering the second amp, see if you like it. And then if you want more, I would suggest buying another sub or only running two. I think you would get more power by just adding or taking away a sub than buying another amp. You can make your amp much more efficient since it can run at 1 ohm. You always want to keep the subs in multiples of two: 2, 4, 8, 16. Precisely because you can be more efficient and have more options when wiiring. If you dont fully understand how to change the resistance levels (ohms) in you amp system let me know and I will post a quick math lesson. It is really simple.
Old Oct 15, 2004 | 11:03 AM
LOTL's Avatar
i dont kno how big the amp fuse is but i will find out(i am not a professional at car audio my cousin is the one he has his own shop and everything im just tryin to get some feedback i just know enough to understand what you guys are talking about). and OZrally im gonna try what you said and see how it sounds at 2.66 ohm and see if im satified with it. I just want some heavy sql im not even looking for sq my mids and highs are nice as *** and give me alot of sq. i just didnt kno if one amp would satisfy me but i guess i'll just have to wait and see. I also didnt want to get 4 10's and 2 amps in my car i think that would be too much but you were saying i shouldnt do it with 2 amps and 3 subs cause of the wiring
anyways thanks for the help guys
Old Oct 15, 2004 | 07:33 PM
OZrallyats's Avatar
yup, how would you power the subs evenly with two amps on three subs. One would be powered more than the others and carry a diff impedence, which might cause it to fire a little off from the others, which can cause them to cancel out eachother, that wont get you sql!
Old Oct 15, 2004 | 08:14 PM
LOTL's Avatar
i might sell them for 2 12' audiobahn if your saying 3 isnt good for one amp, the 12's got like 2000 rms each i think, or what are some good subs with alot of sql, i just want deep bass and alot of it
Old Oct 15, 2004 | 09:05 PM
OZrallyats's Avatar
No,no I didnt say three wont work on one amp. It is not optimal because the ohms are not divided up in the best way. I said that two amps running three subs would be bad. I think you have plenty of power either way you go with subs, you are going to have to be ready to drop serious cash for amp power to push them properly, which then will require several farads in capacitors, super heavy guage power wire. I would do what you decided first. If you dont like it, then swap it or add a amp AND sub.
Old Oct 16, 2004 | 11:04 AM
LOTL's Avatar
another question OZ i can also get a precision power a1200 ppi amp i herd with this amp the more voltage you give it the more rms it would put out i kno somone who has that amp and pushes 2500 rms , if you or anyone has any suggestions on a good amp that can push those 3 subs let me kno...thanx
Old Oct 16, 2004 | 03:57 PM
OZrallyats's Avatar
ppi amps are awesome amps. I dont understand what they mean by giving it more voltage. How would you give it more voltage? The car has a 12 volt battery. The best amp for you would be one that gives its max power at 2 ohms, not the one ohm one you were looking at. My suggestion, any quality amp that has enough power to push three subs at 2 ohms.
Old Oct 16, 2004 | 04:03 PM
OZrallyats's Avatar
One thought, although you dont add volts, you can insure that you dont loose voltage. For example, if your headlights are dimming on the bass, the amps arent getting the power they need. First thing, get capacitors, for a system like yours- Id suggest a 15 farad cap. ( i am only running 2 - 1 farad caps) Capacitors mount in the 12v power line and store an electric charge so the amps always have the power available when they need it, without trying to drain it from the whole car's electrical system. I have seen these added to systems with big improvements. Other things are: make sure your battery is in good condition, and you can have your alternator cheaply rebuilt so that it is charging 120 amps!
Nevaeh
22
Feb 18, 2009 08:32 PM
J8dailo
20
Aug 20, 2008 09:35 PM
J8dailo
Jul 15, 2008 03:19 PM
J8dailo
Oct 2, 2007 10:30 AM
BlkLancer04
Feb 28, 2004 08:45 AM
