Ok, tell me if this should work
Old Feb 21, 2005 | 12:10 PM
taylor25's Avatar
Ok, I've just got a dvd/cd/bunch of stuff in dash and a system of screens. I already have an in dash cd with built in amp (208, 52x4) I want to keep the factory speaker system, but dont want to go through with all the wiring of an external amp, etc.
I ordered the lower din for the deal, and I'm thinking that if I keep the cd player connected to the factory system, then run the dvd player to the audio in jacks on the cd player, it should run through the aux channel. Am I going about this right?
Old Feb 21, 2005 | 12:23 PM
KevinD's Avatar
i'm a little confused by this. did you get a flip out LCD screen/DVD player with an internal amp? or did you get one of those single DIN dvd players that only play dvd/cd/mp3 but you need to run RCA outputs for both audio and video?if you got the second one mentioned then you need a cd player that either has RCA inputs for audio, or you can use a FM modulator and run the audio in through your antenna (****ty sound quality). if you got a DVD player with an internal amp then you can simply replace your radio and run all the speakers with the DVD player.
your second line is correct and that will work.
Old Feb 21, 2005 | 03:22 PM
taylor25's Avatar
Thanks man, I bought one of the ones that just plays the disc, and was gonna run it through my cd player. I hooked everything up and it works great. Thanks for the help!
pastedTOAST
May 27, 2015 02:02 PM
wazzelby
May 14, 2011 11:25 AM
kmartizdatruth
Nov 9, 2010 07:44 PM
Xearo
Apr 20, 2009 05:54 PM
Sano
Jun 7, 2003 12:37 PM
