Subwoofer Polarity Check
Old Mar 8, 2005 | 08:11 AM
wbresson's Avatar
How to you check the polarity of a subwoofer without pulling it out of the box and checking all of the wires ? Using a battery like you do speakers ? Will a AA do or is 9V needed ?
Old Mar 8, 2005 | 08:17 AM
Iamkar33m's Avatar
a 1.5v AA should do this, I wouldnt dare try it with anything of a higher voltage.
if u have ur polarity straight (+ with + on bat and - with - on bat) then the cone should pop out a tiny bit, if u have it reversed the cone will move into the basket.
Old Mar 8, 2005 | 08:18 AM
LEVIII's Avatar
AA prob wont work as it is only like 3.5 Volts or something like that. 9 volt will work. I usally use my batt from my cordless drill. Just make sure both are the same (going in and out t ogether). Going out is posotive on the speaker to posotive on the sub
Old Mar 8, 2005 | 08:24 AM
OZLancerlunatic's Avatar
take 2 wires off the box and plug them into your 120V wall socket.....its ok
um, feel the sub, it will either be hitting in or out.
Old Mar 8, 2005 | 08:28 AM
LEVIII's Avatar
If you do that it will be AC and the sub will be hitting both in and out. And if you hold it there for too long it will blow the sub for you (I know, Ive done it like 50 times on purpose)
Old Mar 8, 2005 | 08:41 AM
maybe i should have put [sarcasm][/sarcasm]
it was a joke....you can actualy get things to light on fire doing that
9v batt works fine or cordless drill batt.
Old Mar 8, 2005 | 11:24 AM
SK Lancer's Avatar
...we have a few home audio subs (Definitive's 8" from the Supercubes) that can be plugged into the wall and left there for long... long... long periods of time and be fine...its fun
Old Mar 8, 2005 | 12:24 PM
BillAce's Avatar
For entertainment in my shop, we plug in old speakers all the time. It's not as cool as putting a CD in the microwave though.
polarity or phase is relative. Being in phase is a time distance relationship between your ears and the speaker. I always try subs both ways and see whcih sounds best. Unless I drag out the IASYS and measure the phase curve in car.
Old Mar 8, 2005 | 12:28 PM
SK Lancer's Avatar
Agreed - CDs in microwaves rock.
We've got a few sub boxes around the shop that are mysteriously tuned to 60hz ... wonder why?
Lightsaber
Feb 16, 2018 05:17 PM
sourtowel
Apr 22, 2013 04:24 PM
saulbyu
Jan 8, 2009 06:15 AM
joedr
24
Dec 31, 2008 07:11 AM
Kurt
Sep 4, 2002 08:43 PM
