Amp turn on lead
Old Feb 6, 2003 | 11:52 AM
cnuila's Avatar
Amp turn on lead
Which wire is the best/easiest to connect your amp turn on lead if you are using your stock deck?
Old Feb 6, 2003 | 08:04 PM
Higgity Hank's Avatar
With the stock deck I guess I'd tap a switched power source, that way the amp can only operate when the car is running, or in the ACC position. Unfortunately, this won't stop the amp from drawing power while the radio is off, but sometimes these are the prices we pay.
Old Feb 6, 2003 | 08:18 PM
jabrien00's Avatar
yeah he is right...I tried to hook it up with the power switch on the oem deck but it doesn't have enough juice to turn on the amp itself..
Old Feb 6, 2003 | 09:02 PM
akaflakes's Avatar
tie it into the ignition fuse. done this many of times and never had a problem
Old Feb 7, 2003 | 06:05 PM
1DVSOZ's Avatar
you should be able to hook it up in the fuse box most cars have a space that is marked acc just make sure that you put a togal switch in the car or the amp will allways be on.
Old Feb 7, 2003 | 11:14 PM
cnuila's Avatar
thanks, guys. I ended up just getting a test light and probing a couple of wires that feed into the junction underneath the driver side kick panel untill I found a good one that was switched with the ignition.
I found out later that might not be a good idea to do, as you can actually fire off your airbag if you mess with the wrong one. I found this out cause after all that probing, my SRS light would not go off and I had to take it to the dealer to reset the trouble code. (I didn't tell them what I had been doing).
The amp works great, though, no other problems, it turns on and off with the car. ba boom boom!
Old Feb 8, 2003 | 12:02 AM
1DVSOZ's Avatar
sweet may you go deff just like me
Ant1
Apr 3, 2016 11:05 AM
evokid511
Aug 23, 2012 06:19 PM
GregGSC
Jul 10, 2012 05:03 PM
BassTek
Jun 25, 2007 11:18 AM
cupOZnj
Dec 19, 2002 01:26 PM
