Another question, grounding problem
Old May 2, 2005 | 05:50 PM
fifty1fifty's Avatar
Where do you guys ground your amps if they're in the trunk? I've got a faint whine that stays the same no matter what volume. It's annoying at low volume so i just crank it up I just ground off a spot of paint in the spare tire well and screwed the ground wire down to that. Just wondering if I should run a wire back from the battery. Thanks
Old May 2, 2005 | 06:09 PM
twardnw's Avatar
I grounded mine to the bolt that holds the hinge for the rear seat hinge in the middle
Old May 2, 2005 | 06:11 PM
lookslikeanevo's Avatar
theres llke 20 grounding points in the trunk...use one of them
Old May 2, 2005 | 06:12 PM
mboza79's Avatar
Ground to bolt in center hinge for rear seats, and be sure you use some steel wool to have a bare metal surface for a great ground. then place hing back over ring terminal and bolt down tight.
Old May 2, 2005 | 06:16 PM
Kbp2025's Avatar
Even if you have a good ground...if you have multiple amps you might need a noise reducer. I had the same problem, they only cost like 30 bucks and are easy as plug and play. Plays clear as day now!!
Old May 2, 2005 | 08:43 PM
I know, that's what I did. Was just wondering if there was a better way since I'm getting a bit of noise. Might have to put a noise filter in tho.
Old May 3, 2005 | 10:08 AM
vrrrm...psss's Avatar
go to walmart.......buy scosche ground loop isolator....problem solved
Old May 4, 2005 | 04:08 AM
brentg07's Avatar
try what was mentioned above and sand away the paint around the ground point so it bare metal and there is more of a contact surface
Old May 4, 2005 | 05:15 AM
camaro379ss's Avatar
i have the same problem with mine, when the whine gets to me i just close my rear seat up b/c my amp is mounted on my rear seat.
Old May 5, 2005 | 09:52 AM
hypo74's Avatar
I am running two PG amps and have them mounted together in the same place and have no ground noise or hum. I grounded them on the right sise of the trunk, right next to the trunk hinge. I actually drilled the hole and screwed them in. Try that.
Old May 11, 2005 | 10:14 AM
peelslancer's Avatar
i have that same "humming" noise and i bought a noise filter and i still got that damn noise...is there a certain kind of noise filter to get or something?
Old May 11, 2005 | 02:18 PM
wiretap's Avatar
Check the wires and all your terminals hooked up to the back of the subs (inside the box and outside).. and the amp terminals. If there is a slight loose connection, check that. (where you crimped the "u-type" connectors on. Make sure you don't have a cell phone with you when you are doing this, or any device that emits EMI.
Old May 11, 2005 | 06:26 PM
Where do you have your noise filter installed? Im not extremely sure that it matters, but I bought the scosche unit, and installed it reverse of how it is supposed to be, between the rca wire and the amp. I believe it is intended to be installed right off the head unit.....for example headunit>noise filter>rca>amp i have mine going like this headunit>rca>noise filter>amp Im not sure that it matters, but try it and see
Old May 12, 2005 | 06:37 PM
sadude's Avatar
as has already been said...definitely sand away that paint and make sure you got some kind of connector there...cleaner installs are always better installs
Old May 19, 2005 | 02:09 PM
ExcessLancer's Avatar
I ground at battery pole!
I ground at battery pole! and head unit and preaps have own power wire at battery pole
