stupid question on connecting wires
Old Aug 18, 2005 | 02:26 AM
AkinaSport's Avatar
do i just connect the wires on the wiring harness and the ones that came with the deck by matching the colors? then plug the white part into the car? thx.
Old Aug 18, 2005 | 05:24 AM
Kurt's Avatar
There should be instructions with the wire harness adapter on how to install it.
Old Aug 18, 2005 | 06:21 AM
wiretap's Avatar
Yea, I just color matched mine before I got the adapter. Go to Circuit City and go in the back by car stereo installs. They have like every adapter you can think of. They aren't supposed to be for sale, but you can haggle a deal with one of the guys. I got mine for like 10 bux. You need the Lancer to Universal adapter. Then plug in your (insert brand here) plug into the universal plug.
Old Aug 18, 2005 | 06:36 AM
kmcconn9's Avatar
umm, ccity does sells these connectors to anbody and everybody, ever if they dont install the radio/components. Well at least they should. All you need to do is connect those two harnesses together by color matching the harnesses. Or like wiretap said, you can go to ccity and get two harnesses: One for your pioneer radio (met-pr0180), and the side for mitsu (met-807001).
Old Aug 18, 2005 | 06:37 AM
kmcconn9's Avatar
The nice thing about the harnesses from ccity, is that if you want to change your radio, all you need is the new radio side of the harness and it will plug right in...
Old Aug 18, 2005 | 11:08 AM
AkinaSport's Avatar
thx for the help, if i knew that type of plug exists i would've gotten that. so can i just join the wires together by electric taping it? i don't have the stuf for soldering and the tools for crimping. sorry for another dumb question.
Old Aug 18, 2005 | 11:18 AM
Tech@SA573's Avatar
You probably could, but I wouldn't recommend it. It could potentially come apart and you would have to take the dash piece back off and redo it. Personally, I would just use wire nuts. I can't remember what gauge wire you would need...I think the size you need will be grey though.
Old Sep 3, 2005 | 06:26 PM
jdjd831's Avatar
Wire nuts are absolutely horrid. You can buy a cheap soldering iron for like $10. Solder! Solder! Solder! Solder! Solder!
Do you get my drift?
Old Sep 5, 2005 | 07:02 AM
kmcconn9's Avatar
couldnt have said it any better myslef...never use wire nuts, they are for house use. Crimp connects and all others are all inferior connections when compared to soldering.
Old Sep 5, 2005 | 07:05 AM
kmcconn9's Avatar
Home depot sells a soldering for like 20.00, and Sears sells a nice one from 35-65. Just make the investment and buy a quailty piece. Its worth the $
Old Sep 5, 2005 | 06:02 PM
jdjd831's Avatar
If your going to spend $60 get this one. It's what I use.
http://buy1.snapon.com/catalog/item....re&dir=catalog
