passenger seat
Old Mar 11, 2003 | 08:05 PM
alive307's Avatar
passenger seat
not sure if im in the wright thread but does any body know how to get the passenger seat out with out un bolting it?....or should i just unbolt it?......and you think i could ground my amp to?
Old Mar 11, 2003 | 10:21 PM
alive307's Avatar
:Bump:
Old Mar 11, 2003 | 10:48 PM
digdat's Avatar
Your gonna wanna unbolt the seat if you wanna mount your amp under there. Will allow you to route your wires easily under the carpet and mount the amp like you would want. I'm not so sure you would wanna do w/out taking the seat out, or could do it without unbolting the seat. It's just 4 bolts, not too bad. Could fit nicely. Remember that those sitting in the back seat may kick it .. so take that into consideration for wire placement.
You could run a ground to the same source as the headunit, but that could be a long wire. You probably could ground it on the body itself, possibly on seat bolt? I dont know much bout grounding :P
Old Mar 11, 2003 | 10:51 PM
cupOZnj's Avatar
ground wire should be same gauge as power wire and no more than 1 foot long. find a bolt on the chassis, make sure it is really clean (sand it down) and ground it there.
Old Mar 11, 2003 | 10:52 PM
HobieKopek's Avatar
I know this is kinda ambiguous as a thread, but I'm gonna move it to A & S since it's for mounting an amp. I just don't want general to get too cluttered so don't take it to heart.
Old Mar 11, 2003 | 10:57 PM
cupOZnj's Avatar
i was gonna suggest this gets moved to audio.
also i wanna say think about mounting it on the rear seat. you'll get better heat dissappation than under the seat.
Old Mar 11, 2003 | 11:08 PM
digdat's Avatar
I agree w/cupOZnj .. Ive got my amp mounted on the back seat. I had to custom make a few mounts for it .. but it works well and looks very clean imo. heres a pic fer ya of my setup
