Need info on what amp i need for this setup
Old Mar 23, 2003 | 02:14 PM
on3ofak1nd's Avatar
Im running 2 of these Volfenhag's
http://www.carstereoexpo.com/zxdvxvol10ca.html
Can anyone tell me what amp i should run that is somewhat affordable but will push well with decent to good quality?
I was considering http://cgi.ebay.com/ws/eBayISAPI.dll...category=18796
For reference, i have an older kenwood 600w amp, and it HARDLY pushes these subs... Although im not sure if the amp is putting out true wattage anyway. This of course doesnt suprise me... im told these particular subs need a lot of wattage.
Any input would be appreciated
Thanks
Old Mar 23, 2003 | 02:35 PM
J'sLancerLS's Avatar
Looks to me like that amp would be perfect for those woofers
The Kenwood is probably only pushing 150w-200w to each speaker, very under powered for those woofers
Old Mar 23, 2003 | 08:41 PM
on3ofak1nd's Avatar
I think you're probably right, the kenwood is just an amp i had lying around, and it is quite old. Does anyone else have any input on the quality of volfenhag amp/subs? I heard these subs at the shop i purchased them from, and with some good power behind them they sounded real nice in my opinion...
Old Mar 24, 2003 | 08:21 AM
lancer02Josh's Avatar
theres no wattage specs on that page for the subs so how can you tell. but i never heard anything good ro bad about them. you should fine a class-d amp. just match the RMS of one sub to the RMS of the amp and hook them in paralell
Old Mar 25, 2003 | 01:13 PM
cupOZnj's Avatar
make sure you hook them up correctly because they have 3 different ohm operations according to that site. get them in a 4 ohm configuration (meaning each sub needs to be wired to work in 8 ohms, then wire them in parallel). this will produce the best responce. it says 800 watts for the speakers but this is probably peak. if you get a monoblock amp that can put out between 800-1000 watts it will push those 2 speakers quite well. giving them more power shouldn't be a problem as long as you don't turn it up to full volume for long periods of time. in fact NEVER turn anything up to full volume. max listening level should be about 3/4 volume for any stereo. tune the amp (gain settings) in this fashion.
llDemonll
24
Feb 18, 2013 10:50 PM
blackevolution8
For Sale - Miscellaneous Automotive
Jan 29, 2010 08:02 AM
jeffers
14
Apr 23, 2008 06:14 PM
kingman4
Jan 24, 2008 07:36 PM
z3bra
Jul 2, 2006 10:03 PM
