Need wiring diagram
Old Mar 24, 2006 | 09:04 AM
davids2004's Avatar
Need wiring diagram
Does anyone have a wiring diagram for the lancer es. Trying to figure out what color wire is which.
Thanks.
Old Mar 24, 2006 | 11:49 AM
dss64bit's Avatar
Hey i have an 05 es (basicaly the same car) why do you need the wiring diagram....?
If puting aftermarket radio in just buy the wiring harness adapter for like 15.00 then all you have to do is color match the wires to your new cd deck. then make it neat by taking your time...then just go and connect that into the factory harness. If you want some pics i can post some for you durring the weekend. Just pm me and i will do it. I am always checking stuff on here so just send a pm...
Old Mar 24, 2006 | 12:48 PM
davids2004's Avatar
I was thinking about putting my stock deck back in but was gonna add a rca converter to the back so I could run rcas so need to know what color or the speakers wires.
Old Mar 24, 2006 | 08:09 PM
dss64bit's Avatar
you dont have to do that to run rca's just go to local audio shop and buy a low pass filter converter...i believe that is what it is called. Doing it this way you can just splice into both the positive/negitive speaker wire for just one speaker. Which should be real easy and simple to do. The speaker wires are usualy white, grey, purple, and i think it might be green but not forsure...its the 4sets that have a matching wire but with a stripe. And with using that box you can then use the rca's like you want too.
Old Mar 24, 2006 | 10:04 PM
davids2004's Avatar
I also need to see what wire to hook up my remote wire as well
Old Mar 24, 2006 | 10:10 PM
dss64bit's Avatar
i will ask my guy that owns his own audio shop about that....then i will post what to do.
Old Mar 25, 2006 | 08:49 AM
Danno's Avatar
The Image was made by Blaze near the begining of time (EvoM Time) so you have to thank that Canuck for that.
I found that some of the wires in my car (colours) didn't quite match the wires in the diagram so be carefull. Regardless, this should help you.
There are many threads on this and I am certian that if you search you will find the answers you are looking for.
Old Mar 25, 2006 | 08:52 AM
Danno's Avatar
Splice in the remote to the cigerette lighter, it is an already fused 12V source that shuts off with the ignition. Just be sure to test the wires to ensure you have the correct one before you hook it all up.
-Danno
Old Mar 25, 2006 | 05:23 PM
diamondstar03's Avatar
I would just use the antenna power booster wire for remote since you are already right there. IMO
gymwrecker
Lancer Troubleshooting
Jul 12, 2016 10:57 AM
bigturboevo80
Dec 28, 2010 02:17 PM
Brokenevo
Feb 8, 2010 04:06 AM
Gurvir19
Aug 7, 2006 02:53 PM
BlkLancer0211
Jul 27, 2005 01:41 PM
