Who was the dude that put his tweeters in the triangle part on the door
Old Aug 3, 2006 | 10:34 PM
sykou's Avatar
Originally Posted by mscc04
Sykou...I think that your tweeter mounts would look a lot better if you tried wetsanding them. Did you use clear coat on them? If so you should fill a bottle with some soap water spray it on the mount sand with 1500grit and then 2000grit. Then use some rubbing compound to take out the scratches from the sandpaper. Finish it up by waxing it with a little car wax.
I used a textured spray paint to make it like that. Kinda leaning towards a more smoother look now tho. After i sand it i kno i'll have a lot of misperfections in the texture, you think i could fill those in with bondo pretty easily or what? How do you work the sandpaper around the curves as not to cut too much into the bondo? I think those two things are my major concern with redoing them.... any help would be much appreciated.
Old Aug 4, 2006 | 04:36 AM
mscc04's Avatar
It probably depends if the textured paint can be sanded. If it can then you wouldn't have to redo the whole thing just the clear coat; however, if this does not work than you would have to redo it. If you use a large enough grit that can take out the pits and then keep working your way to 2000grit you should be fine...the problem is knowing what grit to use...maybe try 800 to start off with but I'm not sure how big you can go before it starts to take off the textured paint and starts to show the material underneath. I would probably wetsand the material by using a soap water mixture like I said before. Just keep sanding until you remove all of the pits. It'll look really hazy but then use some rubbing compound and a little car wax to give it the shine after you clear coat it of course. I don't really think I can help you any more than that...sorry. And I wish the best of luck to you I'm sure there are many people on here that can be more helpful though.
Old Aug 4, 2006 | 02:03 PM
bene's Avatar
Originally Posted by lanport
How did you guys run the wires for the tweeters? I'm thinking of getting some tweeters myself. I want to get 2 for where you guys have yours. and 2 for behind the headrest in the back.
easiest way is to just run it down and splice into the door speakers
Old Aug 5, 2006 | 12:15 PM
TheSeige's Avatar
yeah but then you splice into the midrange speakers
Old Aug 5, 2006 | 11:37 PM
bene's Avatar
stock stereo doesnt make a diffrence, just run them beside the other door wires if you want them wired seperately
Old Aug 10, 2006 | 06:19 PM
AndrewMMueller's Avatar
From what ive noticed.. you guys are going the tap mount... its ugly and bulbous... get low profile inset mounts.. kenwood and kicker have nices.. and drill that out and flush mount em.. little bit more work but looks way better and uses the door as a baffle.. sounds better...
Old Aug 11, 2006 | 12:47 PM
sykou's Avatar
Actually the reason mines are molded into those panels is so i could do that. I made them to fit the JL tweeters if i rememebr correctly. My friend just happened to have a set of tweeters laying around so im just using them temporarily.
ZK
May 20, 2010 11:08 PM
alby988
Dec 31, 2007 09:43 AM
bhaath burner
Jan 28, 2004 02:28 PM
Keyser Soze
Southeast Region
Jul 30, 2003 02:20 PM
veturrapresto
23
Feb 20, 2003 02:33 AM
