Think I can wedge this in my trunk?
Whats up guys? Found a link to a compnay that makes some pretty sick fiberglass boxes.
Think this will fit in an 03's trunk? http://www.tccustomz.com/inc/sdetail/96
Seems like it would be a tight fit. Thanks for the info
The box does appear to be well built. Not to knock them at all, but I did notice that the box has no divider, so both subs will be sharing the air space and may not be as accurate. Just a heads up.
When you click on "more images", that enclosure does have a divider. But the blue one doesn't...interesting. Btw, $200 without a sub isn't much at all actually. There is a lot of work that goes into fiberglass enclosures. Shops charge much more than $200 for custom builds.
its ok to not have a divider. My buddy makes fiberglass boxes for a living and his all sound amazing with an open box. he recently made a box for three subs all sharing the same air space and it sounds ridiculously nice
In an undivided box the subs utilize the entire enclosure, giving them less control than they would have in the correct enclosure size. It also depends on the amount of power that is delivered to the subs. If you're running low to moderate power, in comparison to the subs' power handling, it's ok to go a bit oversized on the box. If you're hitting them with a lot of power, you should really be around the correct box size, or even a little smaller. Running a sub in a larger enclosure than it calls for can cause overexcursion, unless the sub has really good mechanical damping abilities.
I've been building enclosures and doing installs for 19 years myself. One of my installs, before I knew better, comes to mind. I was running two 8s in an undivided box and everyone swore that it sounded like a pair of 12s. That was great until the voice coil completely seperated from the spider assembly.
Thanks guys. Yall are always a huge help. I figure I'll prolly get a custom box from them with a divider and an amp rack built in on the front. Maybe. If not I'll just get their standard box. Looking at filling it with 2 Type-R 12's. I hear good things about those subs.
wow nice fine as your question about if it will fit the answer is yes if you look here http://www.tccustomz.com/customer_rides
You'll see our trunk. Good Luck and btw what type of amp are u using??? I'v been using a TMA t500.1 mono amp works great
Lol, all due respect bro, if it was that easy I wouldn't post the question. Me= Middle East. Car= Virginia. And there lies the problem, lol.
Hope you backs come back soon. Just when you get back post a $hit lot of pics unless i miss that thead.
Thanks man. I'm definitely going to post mad pictures when I get back.
Jellyfishian
Jul 29, 2008 12:22 PM
