Sub help...
Old Jul 27, 2007 | 04:38 PM
depsy's Avatar
Sub help...
Can someone explain the difference between a 2-ohm and a 4-ohm sub, i cant decide which one to get, im getting a rockford fosgate power series 1 and it comes in both options. It'll be running on a power 1000w 2channel amp.
Old Jul 27, 2007 | 04:52 PM
Evodreamer28's Avatar
http://science.howstuffworks.com/question501.htm That pretty much explains it for the most part. The lower the ohms the more power you will have. Thats just a general rule of thumb.
Old Jul 27, 2007 | 07:20 PM
ThunderOZ's Avatar
get a t1 ...
But the lower the ohm the less resistance...
Old Jul 27, 2007 | 09:22 PM
SLVROZ_03's Avatar
The big question is...is the amp 1 ohm stable? Seeing it's a 2-ch, makes me doubt that.
Old Jul 27, 2007 | 10:52 PM
crazy4ozs's Avatar
ditto, check the amp, the amps stability will depend on what wiring diagram you get on your sub
Old Jul 27, 2007 | 11:04 PM
bene's Avatar
no a 2 channel amp would not be 1 ohm stable, it would be 2 ohm stable if its a good amp
optimal conditions are 1ohm stable amp with a 2ohm DVC sub wired to 1 ohm
most people go with 2ohm and some go with 4 but with 4 u draw so much power for it its not worth it
gohdunlam
Apr 11, 2008 10:43 AM
ImJoey
Jun 27, 2007 04:05 PM
xanderracing
Jan 5, 2007 01:00 PM
pumpdog720
Sep 7, 2005 07:05 PM
brentg07
Mar 23, 2005 06:25 AM
