New CD Player... No "remote" wire
Old Aug 9, 2007 | 04:25 PM
BennettOZ's Avatar
Hey all. I recently got a new head unit for my car, its not the nicest but its something new. Its the pyle PLD36MUBT. Link below to unit. Anyways, I was wiring the unit and I noticed that it does not have a wire coming from it that is called remote. the wire that turns on and off my amp when the ignition is turned off. There is an Power Antenna switch can I use that? anyways here is a diagram of the wiring for the head unit.
PS. I also have to use a E.brake wire. I did a search on here and found to just ground the wire and it should work while driving to use the tv tuner and watch dvd at same time. will this work?
Thanks,
Jared
http://www.sonicelectronix.com/item_...PLD36MUBT.html
Old Aug 9, 2007 | 05:12 PM
lancerman360's Avatar
Yes, use the power antenna wire. Its the same thing.
Also, you might want to save some money up now cause the tank of gas in your car might last longer than that cd player.
Old Aug 9, 2007 | 06:19 PM
iufan4lifeul's Avatar
Sad to say but, good call
Old Aug 9, 2007 | 06:47 PM
BennettOZ's Avatar
Yeah, I know... my last cd play went out and I just wanted a fix. so its that. and I will wait to save for something better. but so far I am happy with it. we will see. only time will tell
Thanks again for the help!
Old Aug 9, 2007 | 07:37 PM
no problem
Old Aug 10, 2007 | 12:38 AM
manny_fresh's Avatar
I believe you have to use the yellow wire for the question you are asking
Old Aug 11, 2007 | 12:08 PM
NOTORIOUSLANCER's Avatar
If u use the power antena cable it will shut off the sound when u play the cd/dvd. U need to use the other blue one. And hooking a togle swith to the dvd player will allow u to see movies while driving...
Old Aug 11, 2007 | 12:12 PM
otter's Avatar
EvoM Administrator
You are both incorrect. The antenna wire carries power whenever the headunit is turned on, regardless of which source it's set to.
Old Aug 11, 2007 | 04:30 PM
The Rev's Avatar
use the RED wire, it gives power when the ignition is on. the solid blue WILL NOT give power to amps when any source besides radio is selected. just 14 years experience talking.
ShaneS009
Feb 16, 2011 10:02 AM
bao
Nov 14, 2010 04:49 PM
Spoonie
Dec 23, 2009 04:54 PM
bao
Midwest Region
Jul 9, 2009 04:26 PM
BennettOZ
Mar 7, 2009 05:54 PM
