speaker questions
Old Jul 29, 2003 | 05:55 PM
blaze_125's Avatar
When you pul the HU out, unhook the harness, look where the wires are going and try to pull on them a bit to give you more room to work.
As far as putting a new wire in, you'll see it's not that hard.
Skin the hedge of the new wire and just tap in the harness. Looking straight at the harness, you can tap in the first two pins on the left.
Old Jul 29, 2003 | 06:34 PM
cupOZnj's Avatar
Originally posted by platinum drew
cup, it seems as though you may think I have an amp hooked to my speakers. the only amp I have in my car is for my subs, my speakers are just running off the HU. I've never wired speakers before, so blaze_125's suggestion will take me til tomorrow night at the earliest to figure out, even if I have the wire in plain sight. it's not a matter of getting to the wiring, it's a matter of figuring out how I'm going to reach the wires behind the HU. I can barely reach them to plug them into my HU, let alone see what the hell they are...I dunno how the person who put it in there managed...
well i hope you understand that your bass is overpowering because it IS overpowered, compared to the rest of the system. anyways....pull the headunit completely out. i'm assuming its an aftermarket headunit. check to make sure all the connections to the harness are made properly, they should be twisted together and if possible soldered, or at least crimped or wire nutted.
Old Jul 31, 2003 | 11:36 AM
platinum drew's Avatar
this is gonna sound really simple, but how do you unhook the harness? seems stuck on there, but do you just pull? I can't see any screws (or think of a screw driver that would fit in there easily)...I have a kenwood kdc-419 if that matters (not that I think it would)
Old Jul 31, 2003 | 06:55 PM
blaze_125's Avatar
Usualy you just pull, but you harness might have a little clip that need to be prushed on while the harness is being pulled.
Go gently and everything should be alright.
tronix
Evo X How Tos / Installations
Jan 5, 2014 05:07 AM
bigd31388
33
Aug 20, 2012 07:59 AM
HornstarBU
Lancer How Tos / Installations
Apr 15, 2011 07:41 AM
Tadz0rz
Feb 9, 2009 04:55 AM
bigd31388
Dec 2, 2007 12:22 PM
