Adding 6x9's to stereo
Old Aug 18, 2003 | 09:01 PM
SICKdimension's Avatar
I want to add a pair of 6x9's to run off the hu that will face out the trunk. I don't need to have them running all the time, so should i have a switch that selects either the rears or the 6x9's?
How can i do this safely cause i reeeeally dont wanna screw up any speakers or the hu. I was thinking i could just add a toggle switch?? If this is the way to go, which wire do you block with the switch, + or -
Old Aug 20, 2003 | 09:29 PM
2 days and no replies?!? c'mon guys, this is an easy one...
(some of you may recognize this topic from my other thread)
one more question to tag onto this thread is if i were to get an amp that would power just my 15" home 8ohm speaker (750w) what amp should i get? (keep in mind extreeeeme budget)
Old Aug 20, 2003 | 09:39 PM
import_speedzz's Avatar
You can do this i think... If this will be connected to an amp and not to your headunit, then you can connect the toggle switch to the amp and just turn it off from thurr... I think the speakers should turn off too.. Not sure tho.. Get more opinions.....
Old Aug 20, 2003 | 10:18 PM
RumbleCam's Avatar
easy get a 6-pin switch, wire the negative leads from both sides (r and L) one on each then run both negative from 6x9's to top leads and run positive wire normally and "t" it with the rear speaker positive then into hu
run the neg. from the rear speakers in to the other 2 terminals on the switch.
be sure to run the negatives from the 6x9's to the same terminal pair (Top or bottom)
and the rears to the opposite poles.
then just throw the switch to go from rears to trunk.
If you need more info pm me
Cam L poles switch R poles
L (-) 6x9 | | R (-)6x9
L (-) from HU | | R (-)from HU
L (-) Rear | | R (-)Rear
Old Aug 21, 2003 | 04:13 PM
great! thats just what i was looking for! you think you could make a simple diagram just to make sure we're on the same page? thanks a lot.
what's "Cam L poles switch R poles" ???
Old Aug 24, 2003 | 01:12 PM
Is this setup right? Would it be better to have two switches, then you could switch off positive and negative or is this ok? I just wanna make sure before I screw up anything.
Old Aug 25, 2003 | 07:58 PM
RumbleCam's Avatar
if you wanted you could have two switches but that should be just fine.
when i typed that out it looked better ... oh well
If you go with two switches put one speaker on each switch. dont go bothe negatives on one or you are just defeating the purpose.
Old Aug 25, 2003 | 08:05 PM
RumbleCam's Avatar
L poles.............................(switch)........ ..........R poles
L (-) To 6x9........................|-----|.....................R (-) To 6x9
L (-) from HU......................|-----|.....................R (-)from HU
L (-) To Rear Speaker.........|-----|....................R (-)To Rear Speaker
ok Cam is my name. it realigned the drawing thing when i posted.
with any luck this will look better. i would just draw it but i dont know how to post a pic or anything yet.
the middle things are the poles on the switch looking at it from the back.
Old Aug 26, 2003 | 10:35 PM
great! thanks a lot. i bought a knife switch today (pretty gnarly) like a miniature frankenstein switch. i will do this as soon as i get a chance.
Old Aug 26, 2003 | 10:42 PM
RumbleCam's Avatar
no problem! you should have seen the wild setup i had to run my interiors/ third brake light/ cab light /sex lights in my pickup
Holy-Complicated Batman!
i ended up with three 6-point switches wired together and two pages of hand drawn diagrams and notes!
but it all worked when i was done.
Old Aug 27, 2003 | 09:52 AM
ya, i love doin this wiring stuff, but problem is it doesnt work when i'm done! j/k it usually works, but i always like to ask someone who's done it first. i just gotta get a pair of boxes for the 6x9's and i'll do it!
Robevo RS
Nov 26, 2015 08:26 AM
Nevaeh
Mar 18, 2011 03:41 PM
05_yellow_ralli
Oct 30, 2007 08:07 AM
TRDHarrier
15
Dec 15, 2003 07:46 AM
that_2g_guy
12
Aug 16, 2003 08:51 AM
