2008 Lancer DE...No ACC wire?
Old Apr 3, 2009 | 10:59 PM
jblanton's Avatar
Hello,
i'm trying to install an aftermarket HU in a 2008 Lancer. I've purchased the metra harness #70-7005. The problem that i'm having is that i cannot locate a +12v Switched (ACC) wire in the factory harness. The location of the wire in the metra harness does not line up with a pin on the harness in the car.
has anyone run into this sort of thing before? does anyone know what color the acc wire is on the harness in the car?
Old Apr 4, 2009 | 04:52 PM
Titaztik's Avatar
do you have the Rockford system??? I don't know if it matters but I know the Rockford system does not have a ACC wire. It's turned on via the CAN bus system....hope this helps
Adam
Old Apr 19, 2009 | 07:46 AM
aj_pierce's Avatar
ya there isn't one. you'll have to hook it up to a spot in the fuse panel that will turn on when the car is in ACC mode, like the cig light fuse
Old Apr 19, 2009 | 10:15 AM
yitzac1990's Avatar
well if you bought the correct wiring harness, everything will be fine. wire it up like normal. I did and it works fine.
Charlienofun
58
Mar 10, 2023 03:33 PM
marrawi
Outlander Sport
11
Sep 12, 2021 12:36 AM
primokills
Lancer How Tos / Installations
Oct 17, 2016 08:47 AM
20si06
Mar 31, 2011 09:33 PM
heavyD
Mar 21, 2009 03:46 PM
