Disabling hard wired volume range limiter in Rockford System?
Old Oct 25, 2009 | 06:51 PM
Nathan0490's Avatar
Has anyone established how to disable the hardwired volume range limitation that Mitsubishi had Rockford install into the 650W factory system? I'd like to be able to finally listen to my system at a normal level. I assume it's something in the AMP?
Old Nov 4, 2009 | 12:09 AM
RA121725's Avatar
What is this hard wires volume range limiter?
Old Nov 8, 2009 | 08:29 PM
yitzac1990's Avatar
there is no limitation, its just not loud. 650 watts is the TOTAL MAXIMUM output, the REAL RMS output is mire like 250 or MAYBE 300 watts total....since there are 6 speakers and a sub or w/e, that power gets divided up by more speakers, meaning each speaker gets less power, a.k.a. not as loud. the amp is pretty much just for quality....
Old Nov 16, 2009 | 06:55 PM
Nathan0490's Avatar
You are wrong sir . Many here have noted that it will start out loud and limit itself. You can find the threads on here...
Old Nov 17, 2009 | 08:45 AM
nelsondevicenci's Avatar
Yes has limitation for sure, from 26 to 45 is almost the same at leat in the Navi system.
Old Nov 18, 2009 | 02:36 PM
Nathan0490's Avatar
Yes thats exactly what I'm talking about. It may be in the navi unit itself and not the AMP.
Old Nov 19, 2009 | 11:13 AM
yitzac1990's Avatar
wow that really sucks.....so much for a rockford fosgate upgraded system for an extra $2,000! lol
Old Nov 19, 2009 | 11:28 AM
kcandiloro's Avatar
What inputs are you all listening to? CD/Music Server is quite loud for me, while radio and satellite are quieter. I certainly don't have a problem with it being too quiet. I just up the volume a few notches when on the radio/satellite.
Maybe try turning on/off the selection in the Nav unit for speed sensitive volume/EQ? I keep mine on, but to tell the truth, don't notice much of a difference either way.
Old Nov 19, 2009 | 11:37 AM
kcandiloro's Avatar
Old Nov 19, 2009 | 11:47 AM
kcandiloro's Avatar
Old Nov 20, 2009 | 10:36 AM
Nathan0490's Avatar
Uh, triple post..
45 maxed on Sirius is the same as 30 on Sirius. It's not nearly loud enough. CD and AUX input aren't too bad but still I'd like the ability to go louder.
Just about to head to the dealership to get my blown sub replaced now.
Old Nov 23, 2009 | 12:36 AM
any source if you up the volume the system automatically less the colume and
The speed compensated volume never works since my first day with my car.
Old Nov 24, 2009 | 01:00 PM
kcandiloro's Avatar
Originally Posted by Nathan0490
Uh, triple post..
That's embarrassing. Not sure what happened there...
Old Nov 26, 2009 | 06:20 PM
dyno's Avatar
Even with my windows down I rarely turn it up past 25. But yea, some songs will start out pretty loud and then seems to get turned down 2 or 3 notches. I actually find the speed compensated volume control makes it less noticeable, but that's just me.
20redfire03
Mar 7, 2016 02:27 PM
Scholls
10
Dec 9, 2015 04:11 AM
atombomb33
30
Aug 12, 2010 04:33 AM
skich
Lancer Troubleshooting
Jun 17, 2010 10:30 PM
mooserov
Nov 7, 2009 06:25 PM
