Lights dimming!! Any fixes?
Old Nov 18, 2003 | 11:53 AM
tunaman's Avatar
I already added a cap to my sound system but all the lights in my car still dims when the sub hits. Is there anyway to keep this from happening?
Old Nov 18, 2003 | 11:55 AM
Iamkar33m's Avatar
Hyper-Grounding kit...
It wont get rid of it completely but it will decrease the dimming effect by like 80%
Old Nov 18, 2003 | 12:13 PM
Higgity Hank's Avatar
You don't really need the whole "hyper grounding kit"... just a couple of wires.
1. From the engine block to the frame.
2. From the battery - post to the frame.
That'll help more than you'll ever believe it could. Use 4 ga or larger for the best results, and don't remove any factory grounds. (can't have too much)
Old Nov 18, 2003 | 01:31 PM
TeamNeXusOz's Avatar
its usually your h/u thats sucking all the power...try to find a better way to power it...but i dunno..how to do that...cus...im having the same problems
Old Nov 18, 2003 | 01:37 PM
matt55's Avatar
hyper grounding kit wil do nothing, h/u DOES not dim ur lights------
1st , how much of a amp do you have(watts)/what kind of amp is it?
Old Nov 18, 2003 | 01:40 PM
matt55's Avatar
Hank? once again what the hell are you talkin bout? the amp has nothing to do with the motor(better grounding of the amp would help)
Old Nov 18, 2003 | 01:56 PM
Shadow's Avatar
You need a capcitor and that will stop the dimming. A capacitor stores power and re-distributes it to your amp when it needs it.
Old Nov 18, 2003 | 02:00 PM
bobaab's Avatar
he already has a cap.
Old Nov 18, 2003 | 02:02 PM
Shadow's Avatar
oh yeah sorry, well it might not be strong enough for your amp then.
Old Nov 18, 2003 | 02:07 PM
OZ_03's Avatar
I was having the same problems, i have a 1200w amp and my lights were dimming a lot. I couldn't afford a cap at the time, so i took the optima yellow top battery from my old car and put it in the lancer, bye bye light dimming altogether.
Old Nov 18, 2003 | 02:11 PM
matt55's Avatar
extra batt= prob solved
Old Nov 18, 2003 | 02:23 PM
caps will notsolve everything!!!...i have teoofthemin my car...with two 500w amps...
Old Nov 18, 2003 | 02:31 PM
matt55's Avatar
CAPS=**** good wireing, extra batt, bigger alt that is the best ways to solve the prob.
Old Nov 18, 2003 | 02:34 PM
SNapz's Avatar
Get a better alternator. You need a HO Alternator.
Old Nov 18, 2003 | 02:41 PM
matt55's Avatar
dont NEED better alt by it self amps NEED more power than most alt can produce(100 ampsX14volts=1400watts,BUT amps are not 100% efective they run bout 40-50% for class a/b and 70-90 for class D)so a 700 watt(class a/b) amp needs bout 100 amps of power @14 volts to do that or class d need less, but its still alot
