Driver side keyless entry does not work after amp kit install
Old Jan 22, 2011 | 03:24 PM
SlackerKo's Avatar
Unhappy Driver side keyless entry does not work after amp kit install
Hello,
After I got an aftermarket amp installed in my 2010 Lancer Ralliart Sportback, the driver's side keyless entry (only the unlock) stopped working. To be clear, I am referring to the feature that unlocks the driver-side door if you touch the door handle with a wireless keyfob close by.
Lock/unlock using the remote button still works correctly on all doors, so I don't think it's due to a floating ground signal. Even stranger, the keyless entry from the passenger side or trunk still works, so I don't think it's a programming issue. This is a bit out of domain for the local audio installer, so I need to check it out myself.
If someone can send me a harness schematic on the driver's side door panel, I'd like to check out the wire continuity before I take it into the dealer. Here's what I'm seeing right now, and thanks ahead for your help.
* Keyless unlock operation does NOT work on the driver's side door
* Keyless unlock operation works on the trunk and the passenger doors
* Lock/unlock operation from the wireless remote keyfob works on all 4 doors
* Lock/unlock operation using the driver-side buttons work on all 4 doors
* Power window and mirror controls all work from the driver's side
NeoGearX
14
Jan 9, 2022 01:25 PM
unicycle
Aug 20, 2016 08:25 AM
Skott2k
15
Mar 26, 2009 09:55 PM
WRC4ever
Jan 29, 2004 08:31 PM
