Ex Installer salesman from custom stereo shop offering help if anyone needs
Old Apr 5, 2004 | 09:15 PM
a904dam's Avatar
SkiI, that is a nice looking set-up! Does that box meet your airspace requirements for your subs? I have 2 Kicker Impulse subs in my trunk and the box uses about 65-70 percent of my trunk...any ideas?
Old Apr 5, 2004 | 09:20 PM
a904dam's Avatar
btw, they are 12's
Old Apr 5, 2004 | 10:09 PM
SNapz's Avatar
I have two 12" Alpine Type R's. I was thinking about fiberglassing them into the 2 back corners to save space and then make a false floor for my amps.
Would this be a good idea? Or better to just design something like you have?
Old Apr 6, 2004 | 12:21 AM
skiidaho1978's Avatar
First reply is for the kickers your ideal box would be apporximately 1.25 cubic feet per chamber in a sealed box. My infinities are 1.31. I built it angled like that to reduce backwave and to optimize trunk space. as for the second one with the alpines, id say fiberglass is WAY more expencive and messy its MUCH easier to do something like i did especially if you dont have someone using REALLY good fiberglass and who knows how to use it. just make SURE to use ( liquid nails between the MDF when you put the box together and let it dry SOILD before placing the subs in the box. so NO air escapes the box and you dont want ANY fumes from ANY adhesive in the subs when playing it will deterierate (sp?) the subs when the fumes are trapped behind the sub. hope this makes sence I used liquid nils on EXERY joint then went over the inside with good hot glue. Ptex is also good for the hotglue a lil harder to find but much more rigid. hope this helps guys
HeavensMist's Avatar
I'm pretty much thinking the same idea as snapz, but i want it as light as possible. I also have type R's, and hopefully soon i can get the infinity perfect series subs, 12inch
Old Apr 6, 2004 | 01:30 AM
one thing about the perfects is they have VERY short leads into the sub and tend to break when over excursion happens not always but ive seen a ton returned from it be SURE NOT to buy ebayd subs they wont get warrentied just a FYI. If you put them in a VERY well sealed box with NO air leaks it will prevent this from happening and theyre MONSTER subs if sealed well. as far as light the perfects are not light LOL but if you go fiber it will keep some weight down for sure. Just use good stuff with a person who knows their stuff
Old Apr 6, 2004 | 01:34 AM
i'll just have to find a guy where i live to build one for me and take a chunk out of my wallet lol
DarthBerto
Apr 19, 2017 06:23 PM
cij911
West Region
Jul 14, 2008 08:00 PM
EVOLUTION Vlll
Aug 24, 2006 12:02 PM
Takeoff
10
Dec 22, 2004 09:07 AM
