small stereo problem
Old Dec 20, 2004 | 09:13 AM
Takeoff's Avatar
I have the stereo installed but the piece that goes around the stereo will not clip on. It won't clip on because the stereo sits totally flush with the dash. Has anyone else had this problem and how can I fix it. Thanks.
Steve
Old Dec 20, 2004 | 09:15 AM
twardnw's Avatar
I have this problem, I left mine w/o the trim piece, you could cut at the piece until it fits, or just leave it. You could also possibly mount the HU further in the dash, but that would take some careful custom work
Old Dec 20, 2004 | 09:49 AM
blacklancerr's Avatar
mine did that too, and i noticed that a lot of japanese cars are like that. you don't need it on there, it is just a 'trim' ring. you could also mount the headunit farther out on the brackets, but you would need to drill new holes and i think it would be a pain to line up. you'll get used to it....i didn't even notice mine anymore..............until you said something!
Old Dec 20, 2004 | 10:04 AM
Dookie's Avatar
Here's what I did...
Get some washers for the four mount screws, and install the washers behind the bracket until the radio comes out far enough to clip the cover on. It's kinda of hard to get them on but it's worth it. Works good for me. A little hint to keep the washers together, superglue them. I used 5 of them behind each screw, but it all depends on the thickness of the washer. Also,I think I had to get a longer screw, but I don't remember...you will know if you need one to compensate. (You can get away with doing only two of the screws like this, just make sure that you use opposite corners. I.E; top left and bottom right, or vice versa.)
Old Dec 20, 2004 | 11:53 AM
ItsTheDriver13's Avatar
From: Danville, CA (it really is all about nor cal)
the dude who installed mine told me to just glue the mount piece on. i laughed as i drove away. i dont have my trim piece on. its in the box if the stereo ever sees a diff car
Old Dec 21, 2004 | 11:59 AM
Takeoff's Avatar
Thanks for all the help. I was thinking of the washer trick but haven't tried anything out yet. I wanted to get suggestions first. I am surprised more people don't ask about this. Thanks everyone.
Steve
Old Dec 21, 2004 | 12:02 PM
dizzigital's Avatar
yeah get some washers. what i did was bought a square foot of neoprene and cut it into little squares. i stacked about 3 or 4 and screwed threw them. worked like a charm!
Old Dec 21, 2004 | 12:12 PM
Red Dragon's Avatar
is there a way to move the brackets back? thats how i did mine, i just move the brackets back a notch and it fits perfect with the trim.
Old Dec 22, 2004 | 08:43 AM
Takeoff's Avatar
If that is the way you did yours, how did you do it?
Old Dec 22, 2004 | 08:46 AM
twardnw's Avatar
he moved them back a 'notch' but that would depend on what mouting holes the HU has on it. I know mine only had 1 set. You could probly drill new ones, very very carefully
Old Dec 22, 2004 | 09:07 AM
on my last car i just drilled custom holes in my mounting brackets. that is always an option.
LewisLancer
Lancer How Tos / Installations
Nov 17, 2016 09:42 AM
ashar
Mar 23, 2010 08:32 PM
akumatose
Jan 3, 2009 08:39 PM
gomezgoku
23
Mar 22, 2007 10:03 PM
PenileImplant
Apr 22, 2005 01:17 PM
