rattle
Old Sep 20, 2002 | 06:39 AM
thunderlancer's Avatar
rattle
I know we have been over this topic about 100 times,but
I just had my system installed and it rattles like a *****.
I dynamated the trunk and I still have a vibration off the trunk right along the bottom of the rear window where it meets the trunk. Any suggestions???????????
Old Sep 20, 2002 | 07:01 AM
pinoyesv6's Avatar
try the third brake light.
Old Sep 27, 2002 | 09:01 PM
SpeshalK's Avatar
First your could try point the box forward and as far forward as possible, next where the back speakers are on the decklid, you can try either removing them to let air into the car, or you could change the 6 1/2s with say 5 1/4's which also allows some air into the car and mite help reduce the noise..
Old Oct 9, 2002 | 04:15 AM
lancer02Josh's Avatar
ok it is the deck where the speakers are it is hitting the window i dont know how to fix it my car does the same also my license plate lights rattle i have them tightened all the way and they still do i think they are hitting the bumper from the inside dont they have a dynamatt spray theat i could use to hold them still?
Old Oct 9, 2002 | 04:19 AM
Pimpson's Avatar
In all my years of car audio (6) I have never been able to fully stop the rattle from the liscence plate...grow to either drown it out or love it.
Old Oct 9, 2002 | 06:03 AM
SpeshalK's Avatar
Stoping the liscense plate is sometimes has easy as putting styrofoam behind it, havent tried it with my lancer yet...but it worked in my old car
Old Oct 9, 2002 | 06:52 AM
2wdSQL's Avatar
Dynamat the back of the plate. Add 2 screws to secure the bottom of the plate, have a shop do this. Then buy some foam-rubber weatherstripping(1/2" thick) from your local hardware store and place that behind the plate over the dynamat.
Old Oct 9, 2002 | 06:54 AM
2wdSQL's Avatar
Dynamat only works on solid surfaces, since you car consists of pieces which are placed together like a puzzle and is not solid dynamat is much less effective you need to fill alll the gaps seperating these pieces to make dynamat work for you which requires a lot of work.
Old Oct 9, 2002 | 06:56 AM
cleofis's Avatar
k..about the license plate..get some cardboard..some really thick cardboard. tear off a piece and slide it up near the bolts of the back license plate. this pretty much does what that dynomat license plate thing does with almost no cost. just a quick tip for you guys
Old Oct 9, 2002 | 10:28 AM
its not the license plate its the lghts above the license plate but thanks ill try he cardboard thing first
Old Oct 9, 2002 | 10:30 AM
cleofis's Avatar
yeah..i get that too..i keep trying to find out where the rattlings coming from..but its pretty much in a general area of right behind the bumper..under the trunk..but above the bottom of the car.. its an unreachable area
Old Oct 9, 2002 | 10:35 AM
Pimpson's Avatar
the tools in the spare tire?
if so those are far from unreachable.
Hotshot940
Lancer Troubleshooting
14
Feb 20, 2014 06:11 AM
Rexpeed
68
Sep 19, 2009 06:09 AM
spooch
11
Jan 15, 2008 08:28 AM
neutral
Sep 3, 2003 05:44 PM
LancerFreak
11
Nov 21, 2002 09:38 AM
