Ran Power wire but Slight problem
Old Jun 26, 2004 | 08:48 AM
davids2004's Avatar
Man was that hard or what. Well my problem is I popped out that rubber gourmet that I ran it through and I cant get it back in. Will I have any leaking problems or antyhing if I can get it to go back in or any tips on how to get it back in.
Thanks.
Old Jun 26, 2004 | 09:05 AM
rentaslut's Avatar
you can pop it back in if you can get someone with small hands
Old Jun 26, 2004 | 10:18 AM
davids2004's Avatar
If I cant get it back in will I have to worry about leaking or anything.
thanks.
Old Jun 30, 2004 | 11:46 AM
blaze_125's Avatar
Maybe not, maybe yes. I say do your best to put taht back in where it belongs. Even if it's only half way in that's still better than nothing
Old Jun 30, 2004 | 11:49 AM
SK Lancer's Avatar
ive only seen a grommet leak once...
BUT, i'd get it in there...use a screw driver if ya have to...just get the ****er in there.
Old Jul 5, 2004 | 12:59 PM
dragon lancer's Avatar
were did you run the power wire into the wall ?
when you look under the hood, on the fire wall in the back coner on the passengers
side pull the firewall mat back theres a rubber piece there, take it out run your wire
when you get done put the wire behind the black mat intill you have to turn to the
batter. Zip tie the wire to some rubber hoses put loom around the wire.
Don't worry about eney water coming in because that's how I ran mine and it's dry all the time.
Don't worry about the rubber piece going back cause it won't go, onlse you cut it to fit.
chdvg
Oct 19, 2016 01:17 AM
roguevegas
May 24, 2012 04:16 AM
yellowevo82
May 8, 2009 09:27 PM
2004Ralli//art
04-06 Lancer Ralliart How To Requests / Questions / Tips
Nov 8, 2005 11:17 PM
