Installing stock stero in boat, problem powerin up
Old Jul 3, 2004 | 05:10 PM
Stimulation's Avatar
Hello,
I am installing my old Sh*tsubishi Lancer Stock stereo into my little 9 foot pond hopper. I have everything wired up prosfessionally, got the old harness new from Best Buy (my job), and and ready to solder onto the harness. I wire everything up to check the connections, including the power and ground, and it does not turn on.
I am running power from a 12v deep cycle battery wired all throughout the boat, in addition I have attached the negative from the battery to the stereo's body. Is there any theft protection or anything I am missing out. There is a postive and negative in the harness but no ground (not that I have one on the boat, the negative i assume).
On the back of the radio, it has two round attenna ports (i believe thats what they are) a harness port, for the harness I am usuing, and on the back left bottom there is a round (alot of pins) connection, but I dont remember anything ever being hooked up to that. Maybe a 6 disc?
Anyway, what am I forgetting, doing wrong?
Old Jul 3, 2004 | 05:19 PM
zlancer's Avatar
i don't remember if the stock radio has a anti-theft protection. if it does then thats the problem. you have to enter a code for it to turn on.
Old Jul 3, 2004 | 10:57 PM
SK Lancer's Avatar
negative = ground.
you also need an accessory (switched power) wire
Old Jul 3, 2004 | 11:24 PM
I believe the accesory is it!
I overlooked it, i thought it would be something.
How would i go about hooking up the accesory (switched power, by this you mean power, low voltage like 3 volts I assume) to the acc wire on the harness. Could I just hook up a little auto switch switching the 12 volts to that switch?
Im gonna run and try that now!
Old Jul 3, 2004 | 11:42 PM
ok, I got it. Thanks Guys!!!
I had acc to the negatice because it was black. You know what happens when you ASSume dont you?
Thanks fellas.
Later
NoReason
Jun 7, 2015 07:05 AM
Iamkar33m
Aug 14, 2014 10:13 PM
TwinDragons
Feb 13, 2014 11:31 PM
Xearo
Apr 18, 2009 02:29 PM
cky3396
Apr 12, 2004 11:57 PM
