super duper n00b question about 6 way amps.
Old Jul 21, 2004 | 12:25 AM
Snarlynx's Avatar
Hi, Can I (have someone) install both parts of the sub part of a six way amp. to a DVC sub?
The amp specs are:
56 watts RMS x 4 channels + 107 watts RMS x 2 channels at 4 ohms and ≤ 1%
THD + Noise 148 watts x 2 + 287 watts x 1 at 4 ohms, 14.4V supply and ≤ 1% THD + N2
the sub specs are... umm, 12 inch DVC sub.
more specificly can I hook up a six way amp to one sub, a set of components, and a set of 3-way speakers and make full use of the amp?
It's all infinity if that makes a difference.
http://www.infinitysystems.com
And I chose them because I get a discount.
Old Jul 22, 2004 | 12:18 PM
Higgity Hank's Avatar
Yes, you can hook up the amp that way. With the sub channels, you'll need to make sure they're balanced or you'll end up using the warranty on your new sub really quick. Hopefully the gain on the sub channels is just one knob/dial/screw/whatever, if it's a pair, you're going to need some test equipment.
Old Jul 22, 2004 | 12:19 PM
Of course, I meant the above to mean if you hooked one channel to each voice coil. If they're bridgable, do that. It'll save you a fair amount of headaches.
ToddRhodes
11
Jun 12, 2013 12:12 PM
MitsuJoe
37
Oct 8, 2005 08:12 PM
BlkLancer04
Feb 28, 2004 08:45 AM
platinum drew
Aug 30, 2003 12:37 PM
