8 ohm or dvc?
Old Aug 29, 2003 | 03:41 PM
platinum drew's Avatar
8 ohm or dvc?
really quick question...my amp has been overheating because my subs are both 4 ohm, running at a bridged 4 ohm setting, making the load 2 ohm. I can get identical subs (same specs, brand, model, etc...) in either 4 ohm + 4 ohm DVC, or just 8 ohm, to balance out the load. I know 8 ohm would be easier to wire, but does it make a difference? the price difference is just a few dollars, but will the quality be any different? thanks in advance
drew
Old Aug 29, 2003 | 03:57 PM
illizit's Avatar
ok, if you go with the 8ohm you can bridge it but it will be a 4ohm load which means less power out to the speakers. Go with the DVC and dont bridge it, its the same thing but wont stress out your amp.
second try at explaining it better lol:
the DVC speakers, non bridged, will be the same as your current setup bridged and wont overheat the amp! hope this helps.
Old Aug 29, 2003 | 04:11 PM
purecoda's Avatar
i second the non-bridged DVC route. not as much power, but you'll be running a cleaner, cooler signal.
Old Aug 30, 2003 | 10:00 AM
ok, I'm somewhat confused...isn't the whole point of going the DVC route so that I CAN bridge it without it overheating? I mean, if I'm just gonna run it off of 2 channels anyways, why shouldn't I just keep the 4 ohm subs I have now?
I have my 4 ohm subs (2 of them) running at 700W (peak) since it's bridged, but this makes it a 2 ohm load. if I keep it at 2 channels (non-bridged) it's a 4 ohm load, but only uses half the amp (as opposed to using all 4 channels bridged). with the 8 ohm subs, I could just swap them out, making the load 4 ohm automatically. if I get the DVC, I can wire it in such a fashion that it would get the load to 4 ohm, but still be using all 4 channels (bridged) and getting all the power from my amp. why would it be better to even switch to DVC if I'm just going to use half the amp anyways? sorry, maybe I'm just missing something...
Old Aug 30, 2003 | 10:05 AM
Street Racer's Avatar
I'd say just get a better amp that is capable of handling a 2 ohm load more efficiently.
Old Aug 30, 2003 | 12:37 PM
I plan to do that at some point in the future, but at the moment, money is tight. the subs I actually want I can't afford, this is just a temporary fix.
depsy
Jul 27, 2007 11:04 PM
ImJoey
Jun 27, 2007 04:05 PM
brentg07
Mar 23, 2005 06:25 AM
Mental_Atrophy
16
May 8, 2002 10:01 PM
nyclancer
10
Apr 13, 2002 07:34 AM
