X-over question
X-over question
Might be a dumb question, but hey
I've got a set of old cross-over. It says on the casing that it can't go any higher than 30 watts. Does that mean I shouldn't be using them if I'm pushing my components with 125 watts. Does it matter at all?
Originally Posted by SK Lancer
What kind of XO is it? Post some specs/pics...
They were hooked up in a box I recently took apart. I'm at work right now, so the info I'm giving is off the top of my head.They were made by a company that probably no longer exist
Image. That's the name that's on the sub, and that name is also on the x-over case. Within that X-over, I can seperate 3 channels(low, mid, high). Each channel has it's own output.The way it used to be setup:
Amp to XO
XO to sub
XO to mid
XO to tweeter
The amp it used to be hooked on was a very old amp. I don't even have it anymore.
Ya also dont want to put 80 hz to your tweeters, too
Originally Posted by blaze_125
Might be another supid question, but is there any way to see wich output is which with a mutlimeter?
I'd put some music to it, hook it up to a speaker and see...don't put it to a tweeter tho
blaze, I have a signal generator somewhere here, if you'd like to borrow it, it can generate sine and square waves at various frequencies.. you can also connect a scope on your xover output to see how the signal goes down as freq goes up.. I probably have an old 500kHz scope here that'd be perfect for checking audio stuff.. (actually, if I can't find it, I can borrow one from a friend who got one at the same time I did.. not sure I kept mine after moving 3 times in 2 years..)
fluke
PS: I have some audio stuff I'd like to play with too, I'll show you next time we meet
fluke
ToddRhodes
11
Jun 12, 2013 12:12 PM
baddazzEVO
Aug 29, 2006 08:48 PM
