12 Volt Tap in...
Old Oct 23, 2002 | 07:07 PM
speedyst9's Avatar
12 Volt Tap in...
Can I please get directions on the safest way to tap into a 12 volt power source for more interior lighting without using the cigarette lighter...? Thanks..
Old Oct 23, 2002 | 07:18 PM
[s3]'s Avatar
Easiest way, get one of those light up power lead testers and see where the closest +12v wire is.
If you wanna wire up map lights, tap the dome light, if you wanna wire stuff down under, you can tap wires going to the cig lighter.
Old Oct 23, 2002 | 07:45 PM
pinoyesv6's Avatar
you can also tap the fuse box or directly from the battery. i know when they rebuild my car, im adding a third fusebox to my car dedicated to all my aftermarket acessories..
Old Oct 23, 2002 | 08:04 PM
flameboy54's Avatar
ya, i agree with S3. if you wanna out in neons of LEDs under the seat or something, tap into the cig lighter from behind the dash. gives it the ultra clean look
Old Oct 26, 2002 | 03:49 PM
OZLancerlunatic's Avatar
by "tapping" into stuff you are putting an excessive load on the wire. My reccomendation would be to run new wire, cleanly of course, right through your firewall and make a little junction box near your dead pedal, thats what I did. Dont forget to use the appropriate size wire for the job and the right size fuse. Otherwise, you could have serious problems later on.
Old Oct 31, 2002 | 06:19 PM
theaphextwin84's Avatar
I would also recommend running a new 12v lead into a fuse box to power your accessories. I have always thought it to be best to keep all of the non-essential (but very desired) accessories seperate from the rest of your wiring system just to help avoid anything that could possibly go wrong. Take your time, buy the right wires/fuses and make yourself a nice fusebox and you will have a beautiful wiring system. Also what you could do if you wanted to is to run leads from the new fusebox to either an analog or digital control panel hidden either inside the glovebox or under a seat giving you better access to the power to each individual component you want to add. Peace out enjoy
familymr
AEM EMS
Jun 22, 2016 02:31 PM
8OhOh2
May 14, 2016 05:39 PM
Czarcasm
Mar 11, 2013 01:58 PM
BrewPuBeaver
Northwest Region
38
Nov 17, 2006 04:50 PM
alex_alex
Sep 16, 2003 01:35 AM
