Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
stock EVO beats 500whp STI
Old Nov 8, 2006 | 09:26 AM
BrewPuBeaver's Avatar
had some buddies ask to post this here..
watch the left gauge... fuel pressure...
hopefully i can get this damn fueling issue sorted out soon.
the ECU thinks it is a good thing to shut off the fuel pump and the injectors at random times.... we replicated it on the dyno, so we have the logs... really weird to see the volt meter read 12.98 volts to 4 volts all of a sudden...
http://video.google.com/videoplay?do...23627805&hl=en
Old Nov 8, 2006 | 09:27 AM
Evo31879's Avatar
link not working
Old Nov 8, 2006 | 09:29 AM
eve-slow's Avatar
The ECU does that on a stock EVO?
Old Nov 8, 2006 | 10:01 AM
the Fueling issue is with the STI.
i am using the Utec over the COBB AP.
as well as a speed density tune with a 5bar MAP sensor. i am useing the MAF for idle only. everything else is on a MAP based tune. originally we thought it might be the fuel pump, so i up graded to a Buschur super duty fuel pump. same problem.
hopefully the issue should get resovled this weekend, then i will be shooting for 10`s next season
Old Nov 8, 2006 | 10:31 AM
Jim_Patterson's Avatar
are you running slicks or drag radials?
Old Nov 8, 2006 | 11:20 AM
running pretty much bald rt615`s
Old Nov 8, 2006 | 11:27 AM
uglyevo's Avatar
so you ran a 13 something?
Old Nov 8, 2006 | 11:30 AM
justchil's Avatar
Loose wire or something? I dont think I would have posted this if it were me
Old Nov 8, 2006 | 11:32 AM
SterlingEvo's Avatar
Can't wait to see your runs at full strength!
Old Nov 8, 2006 | 11:52 AM
all the hard ware is 100%
pretty sure it is in the MAP vs MAF set up issue
justchil:
i know the guy i ran against, well somewhat. he is always at the track and we normally BS. thought he would like to see it.
for me going to the track isnt about beating the car next to you, it is about beating yourself. and getting better
Old Nov 8, 2006 | 12:02 PM
vletnguyen's Avatar
um is this dave?
frankling said hi... and um.. you do drive a slow sti.. har har har
Old Nov 8, 2006 | 12:21 PM
lol, AZN Frank just called me.
it is slow now...
Old Nov 8, 2006 | 02:50 PM
Yikes that evo pretty much pulled on you the entire 1/4mile.
Old Nov 8, 2006 | 08:20 PM
ashumo's Avatar
what night was this?
what was wrong the night you were running 12.8 or so? maybe this was from that night.
Old Nov 9, 2006 | 12:18 AM
this was from the week befor the last weekend the track closed.....
only running 16lbs of boost on my 35r due to fueling issues...
hopefully when the car is 100% i will trap 130mph
