ROAD/RACE Piggyback VERSION 2
Originally Posted by gregivq
Make it work with high compression pistons? ^
Or do you want to buy a plane ticket?
i was down at ///RRM on sat and got to take a ride in the car with the new piggy, and i was suprised to see that the car only had one other mod that ting was fast!
Rock you and the guys never stop amazing me
Originally Posted by Boeturbolancer
Tell you what... if you seriously want it to it can. All i need is for you to come see me. I'll do the map for free. Just because it's you and i've been assisting you a lot. Why not do that and then i'll have a map for High compression guys. Feel like a road trip?
A drive from Chicago all the way to California?
Let's start with :
10x
^10 =
I'm on it!!!Unfortunately I will have to go some other way. It sux I can't have the advantage of using this product.
Originally Posted by Lil red '03
Reguarding ease of install...... < all together now > HOW EASY IS IT ????
I need this mod - please < crawling on hands and knees up to rock >
if u made a PB for the stage1 setup i would buy it.....and im sure everyone else would.....to help smooth the fuel and timing.....i would buy it right now....then do a reflash for stage 2 w/ injectors....that would be fuxkin' money.
Originally Posted by blaze_125
I assume it will be considered easier to install since you don't have to tap into the vaccum line which can be confusing for some people.
That was the easiest part of the install for me :shrug:
Not to be a knucklehead or anything.. but how hard is that ??
That was the easiest part of the install for me :shrug:I worked in tech support for an Isp for a year... and sometime what looks like the stupidest thing to do for most is like taking home a piece of the moon for others.
Originally Posted by Z_Lancer_Man
^^ I know, I think people had a harder time splicing and soldering the wires
Would sending a dyno sheet with AF ratio be enough to get a custom map? Crawling on hands and knees to get this thing.
