PB V2 problem... fuel map bogging down! HELP
Old Mar 20, 2006 | 05:33 PM
Tainted Winter's Avatar
Exclamation PB V2 problem... fuel map bogging down! HELP
I have had my PBV2 for about a week or two, and decided to tune. The "download from fuel map" showed "0" all across. We made a map and it would bog down at 2k-3k. BUT... if you gave it WOT, it runs great and pulls better.
I unhooked it and everyhinkis running normal before the PB... oh well...
We'll see how this goes.
Another Question...
It has map A and B... is one WOT?
ANY SUDGESION AT ALL WILL HELP...
Old Mar 20, 2006 | 06:21 PM
sykou's Avatar
I believe the map A is the closed loop and the Map B is the open loop. It SHOULD NOT show 0 all accross i believe. You sure you connected it correctly? oh and WOT is map B. This information is all in the instructions that came with your piggy. Just gotta read the ENTIRE thing. Its on page 14 or something like that.
Old Mar 20, 2006 | 10:01 PM
Page 14!? My "instructions" were 4 pieces of paper stappled together.
No tunning tips, no trouble-shooting, just how to hook it up and how to use the program (like what buttons do what) If you got a BOOK, then i need to contact them and see what's up.
Thank you
Any tips for a fix?
Old Mar 21, 2006 | 06:27 AM
blaze_125's Avatar
You work on Table A only.
Get rid of the 0s and put in 10. 10 represent 100% of stock fuel. So if you enter 9.7 then you use 97% of the fuel from the stock map. If you enter 11, you use 110%. Now imagine what happens with 0.
Old Mar 21, 2006 | 01:29 PM
so.... when you download from ECU, the chart should fill up with the stock numbers right?
Mine was all 0s.
if i hook it up again and read from ECU, will it work? Should it read all stock numbers and i could go from there?
Old Mar 21, 2006 | 01:31 PM
Yeah, it bogs down and goes all lean, then dies....
Old Mar 21, 2006 | 01:37 PM
So... in theory, if you set 10s across the board, it will run stock. Then you can take out percentages to lean it out or add to richen it up. Like 9.7 will lean it out 3%. Am i getting this right?
Old Mar 22, 2006 | 06:07 AM
blaze_125's Avatar
Exacly
Mine was all 0s.
Actually, map B should be filled with 0 all accross the board since we're not using it, and Map A should have mostly 10s and then value from 6 to 9.9. That how it was when I downloaded the map from my piggy. Di you make a backup copy of that map you downloaded? If you did, send it to me by pm and I'll have a look.
Old Mar 22, 2006 | 10:45 AM
After i clicked "download", nothing showed up. When you say 10 is using 100% of stock fuel, does that mean that if all slots were 10s, it will run stock? if so, i could tune from there. I am using a Palm and Autometer sweeper to tune.
My goal for now is for it to run stock WITH the PB... i can then tune.
Old Mar 22, 2006 | 11:38 AM
livelyjay's Avatar
Putting 10s across the board on Map A is the same as running without the piggyback (ie it lets the stock ECU do all the work). Increase/decrease the numbers by tenths, and don't change too much at a time otherwise you'll get confused about what changes yielded what results. A decrease in .1 will lean out the mixture, while an increase will add more fuel. I think my map B is all 10s, I'll have to check it out and get back to you.
Old Mar 22, 2006 | 11:47 AM
blaze_125's Avatar
My map B has 0 values in every cell
Old Mar 22, 2006 | 11:50 PM
Thanks you guys... i think i will go with all 10s, then lean it out from there.
Thaks for the help
Old Mar 23, 2006 | 03:43 AM
livelyjay's Avatar
I'll have to check mine this weekend and see what the settings are. I just upped my boost, so I have to make some tweaks any ways.
