RRM ver.2 piggy **soft ware update** 02 03 lancer
Old Apr 28, 2006 | 05:18 PM
ROCK's Avatar
Originally Posted by mitsuozboi
I know This has been asked a million times (and im kinda lazy to read through and find the answer). so, the ver.2 piggy can be used with turbo as well? I would like to get it but wasnt sure if ver.2 could be used at later date with turbo. I have an auto. thanks.
V2 is not for turbo. For sake of disc ussion , this is refferring to V2 for N/A only.
ROAD/RACE
Old Apr 28, 2006 | 10:37 PM
Handmemyarms's Avatar
woohoo! once i get this update im sure ill be happy as a clam, and will report back once its completed
Old Apr 28, 2006 | 11:23 PM
ROCK's Avatar
Come down Tuesday.
ROAD/RACE
Old Apr 28, 2006 | 11:35 PM
Originally Posted by ROCK
Come down Tuesday.
ROAD/RACE
will do, thanks for the quick responce
Old Apr 29, 2006 | 11:24 AM
Boeturbolancer's Avatar
Ver 2 not for turbo... Ver 1, which hotshot has, is different. They are talking about the V2 in this post.
Old Apr 29, 2006 | 07:26 PM
Bigjoeski05's Avatar
No one anwersed my question. What is the difference between the updated piggy and the orignal?
Old Apr 29, 2006 | 08:32 PM
ROCK's Avatar
V2 piggyback hardware is the same. It is just the software settings that we think changed and are better.
ROAD/RACE
Old Apr 30, 2006 | 04:49 PM
ROCK's Avatar
Here are the setup changes. Lets see if I can get it up here. The parameters that you should change are in red. Copy your map down from the ECU. Save it. Then do these changes in setup and upload entire map. Remember, you are not changing the map, just the software parameters under options.
ROAD/RACE
Attached Thumbnails RRM ver.2 piggy **soft ware update** 02 03 lancer-02-03new.jpg
Old Apr 30, 2006 | 04:51 PM
ROCK's Avatar
Let me know how it works for guys.
ROAD/RACE
Old Apr 30, 2006 | 05:55 PM
Tweak3D's Avatar
im retarted and didn't see it in the instructions, do I flash with the car on or off? or does it matter? other than that I will be good to go. ill post the results asap.
-Justin
Old May 1, 2006 | 12:05 AM
sykou's Avatar
Reflash with car off. Disconnect batt. reconnect and start her up. Ill be trying the new settings in a little bit. Let everyone knows how it goes.
Old May 1, 2006 | 01:01 AM
sykou's Avatar
After the relearning stage i stepped on it a bit harder and it felt like there was a bit more power, most likely because the power curve is a lot smoother. There was no misfiring AT ALL. The only thing is, i have the same problem as the first batch of the piggy's. When i step on it kinda hard, shift at ~3k or so, and shift fast, the engine studders. It feels like a delay in the throttle... Can anyone shed some light on this? thanks
Old May 1, 2006 | 06:41 AM
blaze_125's Avatar
No need to disconnect the battery. Everytime I flash my piggyback, the Ecu goes back into learning mode and I don't ever touch the battery.
Get the map from the piggy onto your computer, make a backup copy of that map, then make the changes on the copy meant for changes, and upload it back to the Piggyback.
Old May 1, 2006 | 08:56 AM
ROCK's Avatar
If battery is disconnected then you did not connect to it correctly. Read software instructions! Basically with car not running but key on (as though it were running) connect, download you existing map. Then open it, Look at options, Change options as described in the picture, upload map to Piggy. Then start the car!
ROAD/RACE
Old May 1, 2006 | 09:19 AM
blaze_125's Avatar
You will learn to work around it. When you shift make sure you don't fully release the gas pedal then shove it back in, that will cause it to studder. Don't let the rev dip to low when shifting. With the piggy, I find that either "granny shifting", or powershifting works the best. So either you take your sweet @ss time to shift the gears, or you powershift them.
