need help
Old Jul 23, 2006 | 10:43 PM
baileysboostdoz's Avatar
need help
i have had my rrm stage 1 tubro kit on for around a week now and the only problem i am having is that when i take it out of gear and coast it sometimes cuts off and sometimes the check engine light will come on but will go off like a day later i was hoping someone can help me with this
Old Jul 24, 2006 | 10:00 AM
SLVROZ_03's Avatar
Do you have a A/F gauge or WB?
Old Jul 24, 2006 | 11:49 AM
i have an a/f but not hooked up yet
Old Jul 24, 2006 | 12:11 PM
SLVROZ_03's Avatar
So how do you know if you're running rich or lean? That could be the problem...
Old Jul 24, 2006 | 03:15 PM
i really dont but i havent had the time to hook it up cause of work
Old Jul 25, 2006 | 09:58 AM
SLVROZ_03's Avatar
Stay out of boost as much as possible until then. Don't make your engine blowup because of it. Oh, do you even have a boost gauge?
Old Jul 25, 2006 | 11:38 AM
Wallesasuaz's Avatar
Well get a boost gauge and A/F... gotta have it before you blow something up. Even thought you are stage 1, you're only probably running about 5psi.
Who did the install for you?
Old Jul 25, 2006 | 12:02 PM
Sicktght311's Avatar
Make sure you're bov is fully recirculated and not venting to atmosphere at all. If it is VTA then you are running super rich during shifts and quick throttle closings. Super rich can throw a CEL. Check your plugs, if they are rediculously covered in black soot, then you know you are running rich like a ****, if they are white and burned then you are running lean. If they look clean, free of any major deposit, and no burned whiteness on the metal, then you have a happy engine
Old Jul 25, 2006 | 01:35 PM
Silens's Avatar
what year OZ do you have?
Old Jul 26, 2006 | 04:06 PM
2002
Old Jul 26, 2006 | 04:07 PM
Hotshot940's Avatar
I've experienced / heard of this problem with the piggyback while running stage 2, but not with stage 1 that i can recall. Have you messed with the idle screw in the throttle body at all?
Old Jul 30, 2006 | 02:11 PM
nope
