RRM Piggy back VS. SAFC II
Old Aug 14, 2006 | 06:26 PM
sadude's Avatar
Quick question...If I had a carpc then would that make the piggy equal to the SAFC...would that allow me to tune more on the fly since I would have a computer in my car that would allow me to view the tuning of the piggy.
Old Aug 14, 2006 | 10:05 PM
revolt4revolver's Avatar
yes i suppose, but y? ahaha when u can have it all in one, and regulate things on a 3 inch screen at all times.
Old Aug 15, 2006 | 02:25 PM
twisty1251's Avatar
^^^Why so many screen names 'Civilianrage'?
i like the piggy because you can control an additional(5th) injector independently. Also the ability to datalog lots on information is nice. I can datalog and then sit back and make a tune for my car while watching TV and drinking a soda. lol. different strokes, different folks.
What wideband are you using revolt4revolver? you ARE using one right? narrowband is for girly men.
Old Aug 15, 2006 | 08:35 PM
this is my only screen name on this site, and it will BE my only one. civilianrage is my name on sclc. thanks for playing twisty. i didnt want it to get ghey so take it to pms if u have a problem, keep this informative for other members. period
i have a zeatronix wideband,i have no problems backing what i say. kevin will vouch after saturday, and dont majke this personal, just trying to be informative, piggy has points of stregth, as u listed. as does other types of afc's.
have fun being a *****
Last edited by revolt4revolver; Aug 15, 2006 at 08:53 PM. Reason: added foto for him
Old Aug 16, 2006 | 03:46 PM
bahamut's Avatar
Those two products are different in their own way.
If a person has no knowledge or the will to tune himself nor the desire to muck around the ecu harness, the PB is the way to go. All the homework is done for you.
If you like the flexibility of tuning on the fly, the AFC is the way to go. Yes, it has its drawbacks: funny O2 blue wire readings at times from certain makes and driver experience, hacking up the ecu wires and probable loose connections, and probably not makes the MOST HP gains.
Right now, amongst the mirage guys, we're R&D'ing some stuff to make some sort of ROM emulator, a G93 is non-flashible. Basically, do our own flashing if possible.
Old Aug 17, 2006 | 08:58 AM
ILovE WHEELS's Avatar
i heard that the piggy back makes ur car idel funny, wht about the safc does that do the same thing?
Old Aug 17, 2006 | 09:34 AM
no idle problems with safc, or engine codes.
Old Aug 17, 2006 | 03:05 PM
bahamut's Avatar
There will be no funny idle on the AFC, unless adjusting the A/F ratio correction near idle rpm incorrectly or wrongly setting the MAF/Karmon as hotwire or MAP.
CEL will not come on, unless changing your MAF setup.
Old Aug 17, 2006 | 03:10 PM
there is a differnce in the safc rpm and the rpms on my gauges in my car. why is this? i tyred to adjust the cylinder settings but to no avail
Old Aug 17, 2006 | 05:27 PM
blacklancerr's Avatar
can't wait to check it out pete! should be good with the new exhaust also.
Old Aug 17, 2006 | 06:47 PM
mmmmmmmmmmmmmmmm, exhuast. mmmmmm kevin with a rear lip!!!!! woot!
on topic: i did some tuning today, cutting fuel another 3 percent! WOW! power all over the place.
Old Aug 19, 2006 | 05:16 PM
bahamut's Avatar
It shouldn't, unless grossly off like +500 rpm or misconnection on the wire.
Another factor: visual cue. I know I can't really watch the road, glance at the speedometer, and the AFC all at the same time. When your brain finally processed all the necessary info, your AFC should be off like 100 rpm, that's it.
To Truly gauge it: have a second person with you. As you go through the rpm and reporting it out loud, the second person should confirm the reply. A few more rpm before making any final announcement.
As for setting, from experience, everyone's will be different, due to mods, climate, and driving style. Yes, there are some basic, but it should be done with some sort of O2 reading. Narrowband might not be 100% correct, but it's good enough for NA purposes.
As for running lean, I don't know how you guys are doing it. I never really encountered it on my G93; then, I did one for a lancer in Vero Beach . . . pig rich all across the powerband and virtually eliminated his back firing problem after tuning.
On my G93, my BEST power for O2 reading was .92 . . . .94 was at max allowable. .96 to .98 is stalling at idle. AT WOT with friends in the car, I had hit 1.13, wasting tons of gas w/ no power. The lowest setting on my O2 reading floated .82 to .85 . . . G94 might be slightly different since the lost of 500 rpm comapring to the G93.
My biggest tuning problem was between 4.4 to 5.2K rpm . . . ran rich at WOT.
Noize
25
Sep 22, 2008 12:59 AM
Zippo41189
Lancer Engine Management / Tuning Forums
May 26, 2006 10:46 PM
smokey
10
Jul 18, 2005 05:16 AM
NITROHEAD
Lancer Aftermarket Forced Induction Tech
Jul 12, 2004 02:32 PM
rhyzin
Lancer Troubleshooting
Nov 21, 2002 06:57 AM
