piggyback and CEL
Old May 3, 2007 | 06:52 PM
PGDlancer's Avatar
hey bud, start your own thread instead of repeatedly posting about the same problem in multiple threads if you are that concerned with it. Like I said to the guy who started this thread :
Originally Posted by PGDlancer
sounds like a connection problem. My piggy definitely did the same thing with cel and idle because of 1 faulty connection. ...... Good luck and call Rock in the morning.
if it's not a connection problem, rrm will straighten it out for sure. just call them
Old May 4, 2007 | 11:48 AM
wOZrally's Avatar
Originally Posted by DickMorgan
So i took my car down to RRM yesterday and gabe told me i had mixed 2 wires. I was sure i had done it right but apparantly i was wrong. Thanks to rrm for their help, i fixed the wires then and there, using their tools , which they were pretty cool about by the way. So yeah, everything is all good, no CEL and the car is running lean and mean
what wires did you mix up?
Old May 5, 2007 | 11:09 AM
ROCK's Avatar
This is all resolved right?
ROAD/RACE
Old May 7, 2007 | 06:52 AM
wOZrally's Avatar
ROAD/RACE
no..im still having problems...i have a code for random misfire. i tried switching the wires like he did but 10 seconds after i turned it on the CEL came on and well that couldnt be the problem. i rewired everything and put the two wires back and im gettin CELafter driving like 70 miles. what im thinking is that its the coilpacks if its not the piggy
Old May 7, 2007 | 08:37 AM
ROCK's Avatar
RUn it. The CEL will turn off. IT is not a problem. OR call and ask for ROB.
ROAD/RACE
Old May 7, 2007 | 11:01 AM
wOZrally's Avatar
ROAD/RACE
so it should turn off? whats going on is the ecu learning? the sputtering is ganna go away once it fixes itself?
Old May 8, 2007 | 09:08 AM
ROCK's Avatar
IF it sputters the ncheck connects. We installed one at our shop yesterday and messed up too. IT is quite possible. My guy told me he hooked it up right, insisting. I insist harder though. HE came back and said you were right. The power wire was loose. After that car ran great!
ROAD/RACE
Old May 10, 2007 | 01:16 PM
wOZrally's Avatar
yes it sputters. the cel went away for a few days and it jus now came back again. the one at your shop... was it sputtering to? if so, what wire was it? which is the power wire?
Old May 10, 2007 | 07:19 PM
Newfoundlancer's Avatar
Case and point... get a more experienced person to look over the install. Definitely something done wrong.
Old May 10, 2007 | 07:43 PM
ROCK's Avatar
The red one but the point is that people are installing them used, buying the one that is not compatible wit htheir car, no instructions. If you bought it new from us then give us a call. You are doing something wrong. 90% oof you guys have no problems and we have not seen a single bad box in over 2 years.
ROAD/RACE
Old May 11, 2007 | 10:10 AM
wOZrally's Avatar
well as much as feel i did it right ...i guess i am doing something wrong. i took it off anf reset it and its running normal so i must have done something. and it was new
Old May 11, 2007 | 05:46 PM
ROCK's Avatar
Glad to hear it.
ROAD/RACE
Old May 31, 2007 | 01:07 PM
wOZrally's Avatar
yep....ive given up on the piggy.... ive tried countless times to try to get it working right.... still misfires. and i know its not my car because when i take it off the piggy it runs great. ive had multiple friends check it themselves see if i did it right and they agree its on there right. i mean how hard could it be its only 5 wires... SO i think the piggy might be for something else or mapped wrong.
Old May 31, 2007 | 01:09 PM
crypto's Avatar
Former Vendor
^why don't you just have RRM reflash it, it only costs like $40
Old May 31, 2007 | 09:11 PM
ROCK's Avatar
IF you bought it new from us in the last couple months, call me. It may just be something that happens when you connect the piggy but not the piggy. Does that make sense?
ROAD/RACE
