piggyback and CEL
Old Mar 4, 2007 | 12:16 PM
DickMorgan's Avatar
piggyback and CEL
did anyone have any problems about the CEL coming on after an RRM piggyback install??????? i'm almost positive i connected everything right.......might have to recheck my sodering but it came on......and i'm just curious if someone else had this happen, i might drive it down to pep boys to get the code read
Old Mar 4, 2007 | 12:47 PM
DickMorgan's Avatar
ok......i drove it around.......it's idling high, at 1100 rpms when it should be around 500-600 . When i turn off my car, i can still operate the power windows and the sun roof, lol whcih i find odd, i hope it doesn't drain the battery. I'm going to recheck my wiring and see if if i can do a better job
Old Mar 4, 2007 | 01:02 PM
grubiaco's Avatar
When I first installed my piggyback from RRM when I was N/A I had the cel come on after 10-15 mins of driving it. Do you have a testpipe or headers, if so try to extend the 2nd o2 sensor and it should go away. Or at least it did with me.
Old Mar 4, 2007 | 01:04 PM
grubiaco's Avatar
If it helps, my cel light goes on every now and then since my piggyback reflash. All and all it isn't anything to worry about just make sure you check your codes.
Old Mar 4, 2007 | 01:12 PM
DickMorgan's Avatar
yeah all i have is CAI, crank pulley and piggy back. No exhaust or header. Um i drove it around, i think it's running rich cause i can smell a little gas, i double checked my wires.......the black wire connecting to the black wire on the ECU was loose, actually really loose, i just tapped it and it came off so i resodered that sucker on there. I'm resetting my ECU so i'm waiting a few minutes till i turn everything on. I'll probably just have the code checked either at pep boys if i have time, or when i go to my auto classs.
i'll keep u guys informed if anything else happens
Old Mar 4, 2007 | 01:13 PM
DickMorgan's Avatar
Oh!! one other thing, were your windows still able to roll down for a few minutes after turning off the car??????? i was scared cause i didn't know if it would drain the battery......i'm still able to roll up my windows and sunroof for a few minutes after i shut the car off
Old Mar 4, 2007 | 08:54 PM
PGDlancer's Avatar
sounds like a connection problem. My piggy definitely did the same thing with cel and idle because of 1 faulty connection. As for the window life after death, I don't know. Good luck and call Rock in the morning.
Old Mar 4, 2007 | 09:03 PM
kfos01's Avatar
I can roll my windows up and down for like a minute after the car is turned off. That's supposed to do that. I've had 2 Lancers and they have both done that. It's kinda like a convenience thing. But, it should stop working as soon as you open the door I think.
P.S. I don't have the piggyback...I'm just talking about normally/stock
Old Mar 4, 2007 | 09:18 PM
DickMorgan's Avatar
i didn't use connectors, i sodered the wires together.
Old Mar 4, 2007 | 09:57 PM
eehjay's Avatar
Didn't you have a CEL after installing your intake? Or was that just a weird smell? Could be from that. I'm guessing you have the V2 Piggy. I had the V1 and didn't have this problem. Also, the window thing is normal. It's set for like 45 seconds or something, or until you open your door. It's like how the headlights turn off automatically if you take your key out then open the door with them still on.
Old Mar 4, 2007 | 10:19 PM
DickMorgan's Avatar
No i didn't have a CEL after i installed the intake. it was just the wierd smell. I just got dont rechecking my wiring and everything is right as the instructions say. i'm resetting my ECU right now, it started idling at 750 rpms.......but then went back to 1000 and the CEL came on again
Old Mar 5, 2007 | 04:56 PM
DickMorgan's Avatar
ok quick update......i started my car today......and the first 10 seconds it was idling wierd, kept jumping up from 500-1200 rpms.......and if i pressed in the gas pedal, i could smell gas so i'm guessing it was dumping in way too much gas it could burn off.
I did bend a little bit of the honey combs on my MAF.......that could be it, but i'm taking my car down to RRM when i get a chance maybe drop by pep boys and have them read the CEL code.
Old Mar 5, 2007 | 05:15 PM
Drewbell's Avatar
Im having the same problem. check out my thread. https://www.evolutionm.net/forums/sh...d.php?t=253474
i called RRM today and they told me to check the connections. so i did, reset the ECU and did the 10 min idle and 20 min drive. when i pulled my codes it was saying a misfire, but i also checked each plug with the scan tool at school, and every one was fine, so it was a phantom code. good luck with your problem, ill tell you if mine goes away.
and about the windows working after you turn the car off, its supposed to do that, like eehjay and kfos01 said, its a convenience
Old Mar 11, 2007 | 01:55 PM
DickMorgan's Avatar
So i took my car down to RRM yesterday and gabe told me i had mixed 2 wires. I was sure i had done it right but apparantly i was wrong. Thanks to rrm for their help, i fixed the wires then and there, using their tools , which they were pretty cool about by the way. So yeah, everything is all good, no CEL and the car is running lean and mean
Old May 2, 2007 | 08:09 PM
wOZrally's Avatar
so i put in my PB and turn it on and idles crazzzy enough to shut off and then it stabilized a little bit and i let it ilde for like 30 min and was still idlin funny. so i drove it and it was fine..only a slight rough idle. later i drive to the gas station after filling up my CEL came on...used 89....and ilding wacko.. i wired and soldered everythin like im suppse to and my car was running perfect before i put the PB on
