Needed: Piggyback Map
Old May 21, 2007 | 12:14 PM
Stevos OZ's Avatar
Hey guys,
New to the forum....
I'm looking for a map that has already had some tuning done with it. I want to start with that and go from there.
2004 OZ
Mods: RRM Piggyback, RRM Headers, Ported Throttle Body, RRM Intake Manifold, CAI, Apexi Exhaust, RRM Pulley.
Coming Soon: Plugs / Wires, Ported Head, Cam, Turbo or engine swap.
Old May 21, 2007 | 02:28 PM
kungfugirl's Avatar
isnt that what u have right now? a map with a base tune on it?
Old May 21, 2007 | 07:21 PM
Newfoundlancer's Avatar
Originally Posted by Stevos OZ
Hey guys,
Mods: RRM Piggyback...
^ +1
Old May 21, 2007 | 07:25 PM
kungfugirl's Avatar
I think you hsould purchase the zeitronix unit, with egt and datalog for a couple hours. then sit down and tune accordingly.
Old May 21, 2007 | 08:07 PM
iufan4lifeul's Avatar
I will sell you the map I had tuned for a Pulley, Intake, Ported IM, Header, and Muffler for like $20. They aren't cheap to make.
Old May 23, 2007 | 03:13 AM
sykou's Avatar
Okay to be honest i think you should get a good quality wideband such as the Zeitronix(menthioned earlier), Aem Uego Wideband, Innovate Wideband etc. Then do some runs and see what AFRs your hitting thru the RPMs. Everyone will have different AFRs due to mods. Use a laptop to tune out the AF mixture accordingly. Maybe someone on the forums can help advise as to how many points to reduce it by etc... Oh and BTW RRMs map should run around 12ish AFR with the mods you have listed. So ya read up a bit on the tuning portion of the Split Second manual and you should be set on how to do it.
Old May 24, 2007 | 01:26 AM
when I went to tune the stock RRM tune with my piggy when I had it, it was mostly around 11.5-12.1 AFR's which was, well, not so great. Tuning it DEFINITELY helped
Old May 24, 2007 | 02:59 AM
sykou's Avatar
^ ya the map is a bit rich but its WWAAaayyYyyy better than the stock ecu settings...nevertheless a little tuning can make a big difference on it.
Old May 24, 2007 | 02:31 PM
kungfugirl's Avatar
13 afr NA ftw
