ecu swap on a 2002 lancer es
Old Jul 26, 2007 | 03:51 PM
althekiller2's Avatar
just wanted to know if i can swap out my stock ecu with an evo8 ecu. where would i be able to find one and how much would it cost me?
Old Jul 26, 2007 | 04:18 PM
SLVROZ_03's Avatar
I doubt it and why might I add?
Old Jul 26, 2007 | 04:22 PM
ambystom01's Avatar
No and more importantly why would you want to? The evo engine is not even close to the same as what's in your lancer, the only thing they share is the displacement. It's also turboed so the map would be completely wrong anyways.
Old Jul 26, 2007 | 09:17 PM
lancerrally45's Avatar
but what if you are turbo'd? would you have to add all of the evos sensors?
Old Jul 26, 2007 | 09:19 PM
ambystom01's Avatar
Yes and everything else that makes an evo an evo.
Old Jul 26, 2007 | 09:31 PM
so have you hurd of anyone trying it?
Old Jul 26, 2007 | 09:35 PM
ambystom01's Avatar
No because 1. it would be very difficult to do since the evo is nothing like the lancer, it has a completely different engine, additional sensors, different drivetrain, etc. that all require a different ECU and 2. there's no point in doing it, with the availability of reflashes and piggybacks you can do everything you need using the stock ECU.
Old Aug 11, 2007 | 08:36 PM
ok where would i be able to find an ecu to replace the one i have on my 02 lancer es? instead
Old Aug 11, 2007 | 09:08 PM
mitsuman6's Avatar
You don't need to replace your ecu. Your best bet would be a piggy back or a reflash. Road Race sells a piggy back that comes with a base map on it so it is basically plug and play. There are also other boxes that would need to be tuned once installed. I'm not sure about the reflash so you will have to look that up on your own.
Old Aug 12, 2007 | 06:28 PM
iufan4lifeul's Avatar
Lancer- SOHC, turbo would run 7-8PSI
Evo- DOHC, Mivec, 19PSI.
MAJOR difference in the tunes.
Old Aug 12, 2007 | 07:17 PM
Blacksheepdj's Avatar
No replacement ECUs. You can get a piggyback unit (RRM, SAFC, Emanage), you can get a reflash (Works), or you can get a standalone setup.
What are you trying to accomplish? Give us some more/better details so we can help you.
Old Aug 23, 2007 | 01:23 PM
Chizilds's Avatar
I assume the WORKS re-flash torches any deals by the stealership correct? Where as the Piggy is removable. any benefit to the re-flash over a Piggy?
Old Aug 23, 2007 | 01:26 PM
ambystom01's Avatar
A reflash doesn't require splicing and it maintains all the factory function of the ECU. You can also raise the rev limiter and do other things with a reflash.
Old Aug 23, 2007 | 01:27 PM
i personally like the reflash, you can adjust timing if you have right stuff were as piggy, you can only change the fuel maps.
ps i really wanna go standalone! haha, anyone have one up for sale?
jameswwt
Feb 15, 2016 05:59 AM
envdevo9
Nov 7, 2014 09:25 AM
Tractionlimit
May 6, 2009 02:58 PM
Dyrexion
18
Feb 16, 2009 12:23 AM
drucea
Mar 31, 2008 08:10 AM
