RRM Piggy Back ECU - Question
Old Jan 25, 2008 | 04:52 PM
FinestSoldier's Avatar
Then don't do it bro. its not that important
Old Mar 3, 2008 | 06:28 PM
dejesus360's Avatar
How much performance does the the RRM Piggyback give you? Is it worth the $400 dollars to even consider installing it?
Old Mar 3, 2008 | 09:26 PM
LuDa's Avatar
that and where can you buy it at??
Old Mar 4, 2008 | 02:44 AM
08GTSMayhem's Avatar
RRM's website would probably be a good start to find their product...
Old Mar 6, 2008 | 09:11 AM
Blacksheepdj's Avatar
Before LuDa posts again asking what the URL is...
RRM webstore
MT version
CVT version
(Don't know which he has, since his profile lists a Supra...)
Old Mar 6, 2008 | 01:15 PM
No faith in people using google do ya?
Old Mar 6, 2008 | 01:35 PM
I'm an aethistic cynic. I don't have much faith in anything...
Old Mar 24, 2008 | 05:55 PM
elpoole's Avatar
thinking of installing a piggy and need a copy of the directions for which wire goes where. Anyone got a copy? I want to know whats up before I do it.
Old Mar 25, 2008 | 12:40 PM
elpoole's Avatar
No one got the wiring specs?
Old Mar 26, 2008 | 11:27 AM
SeRious08's Avatar
I have them. I'll post them tomorrow. Just shoot me a PM and remind me. Not only that, if you look at my Piggy Evaluation post, it will explain some.
Old Mar 26, 2008 | 05:42 PM
gtslancer08's Avatar
i just got piggyback for my lancer cvt. so i was bored decided to go out side since it was a nice day to install it. wires are pain in the *** soo tiny. anyway i was doen installing the pigg started the car and engine light came on and my car was bogging down trying to stay started. check my connection everthing was fine since i soldered them. i reliezed in the instructions it say to cut the maf wire which was blue. well there is a light blue wire and dark blue wire, si i cut the dark blue one the 1st time and that was happened. so i called RRM they said itas prolly the light blue. so i treid the light bluw one with the same results. i have no clue whats wrong. so i uninstalled the piggy and now car runs finr, minus the ecu wires being kinda cut up, but anyway, does anyone know what i can do to fix it or what. me running 93 octane have to do ne thing with this. need help asap. thanks
Old Mar 26, 2008 | 08:00 PM
elpoole's Avatar
That is some seriously ****ed up bull****. Their advice was to cut the other wire? It was probably the other wire?
Were the directions not crystal clear? Do you have things done to your ride that would inhibit its functionality?
Anyone else have problems like this?
Old Mar 27, 2008 | 07:49 AM
the_cosworth's Avatar
^^ I had a friend who installed one and he got a CEL but not right away
Old Mar 27, 2008 | 09:46 AM
bigstott's Avatar
If you can post some pics of the wiring you did. I have the Piggy on my CVT and i works fine. Maybe something got screwed up.
Old Mar 27, 2008 | 01:54 PM
SeRious08's Avatar
I was the original tester for the piggy and found the directions crystal clear. In the directions it shows which pin on the harness that you have to splice into.
My guess is that you switched the green and purple wires. You do cut the dark blue wire in two. You then wire the green wire from the piggy to the MAF side of the blue wire. Then wire the purple wire from the piggy to the ECU side of the blue wire.
