ECU Definition file for 2002 lancer oz
Old Mar 14, 2008 | 04:19 PM
PaulysLANCER's Avatar
Unhappy ECU Definition file for 2002 lancer oz
Hey guys i've been searching on the internet for 2 days and I still cant find a definition file for my ecu. My internal ID is 98720009, and my memory model is
sh7052
evoscan works great I can get data from that, but ecuflash no worky, no addresses for the data.
can anyone please help me out?
Old Mar 14, 2008 | 09:32 PM
senate6268's Avatar
sh7052
Post your ROM file here:
https://www.evolutionm.net/forums/sh...d.php?t=334394
I'll make a definition file for you so you can tune with EcuFlash.
Old Mar 25, 2008 | 02:38 PM
senate6268's Avatar
^^^^^^bump
Old Mar 25, 2008 | 05:23 PM
darkmitsu's Avatar
there seems to be something wrong with that def file or is it something im doing wrong.... injectors scaling shows up as 1 . rev limiter is 158 . stationary rev limiter is 19 . its close but no cigar yet.
Attached Thumbnails ECU Definition file for 2002 lancer oz-new-bitmap-image-2-.jpg
Old Mar 25, 2008 | 06:04 PM
senate6268's Avatar
I'm guessing you're using the newest version of EcuFlash. There's a setting that needs to be changed with the endian values. I'm not sure what it is. I still use version 1.29a because every version after it had lots of bugs and didn't work right. The definition file is fine. You need to change a setting in your version of EcuFlash.
Old Mar 26, 2008 | 05:25 PM
darkmitsu's Avatar
you are right thanks much for the help, i downloaded the older version from http://freon.shackspace.com/car/ecu%...tuning/openecu
Stradale
Dec 3, 2025 09:12 PM
mrfred
Dec 7, 2015 01:49 PM
EvoIXPilot
Feb 6, 2013 08:55 PM
mrfred
Dec 2, 2009 02:00 PM
mrfred
May 7, 2009 06:24 PM
